ControlDefinition check if is already active before execute
mirkomaga
mirkomaga
Bye,
I would like to know if it is already active before Execute.
    Dim oCm As CommandManager
    Set oCm = ThisApplication.CommandManager
    Dim oControl As ControlDefinition
    Set oControl = oCm.ControlDefinitions.Item("AppLinePropertiesToggleCmd")
    oControl.Execute
nedeljko.sovljanski
You must be in sketch env. and than property Pressed will show button state
That means you can run your code if you are in sketch drawing env and you will see how pressed prop. changes vaalue depends is button pressed or not.
