Control "Change Arrowhead" on Drawing View
ngdnam88
ngdnam88
Dears,
I'm trying controlling "Arrowhead" on drawing view like this. Is it possible to do it?
I wanna do it in case: If value dim = a and drawing view is 1:10 then change arrowhead to...
Please help me. Thanks!
TomaszDabrowski
You can try to adjust the following rule to your needs.
In line 3, set the desired value conditions (I set it to values less than 100).
In line 4, set the view scale (I set it to 1:10).
Also - consider checking the dimension type (should it work for all dimension types, or just for linear?)
Dim oDoc As DrawingDocument = ThisDoc.Document
For Each dimension As DrawingDimension In oDoc.ActiveSheet.DrawingDimensions
	If dimension.ModelValue <10 Then 'divide value by 10
		If dimension.IntentOne.Geometry.parent.scale = 0.1 Then
			dimension.FirstArrowheadType = ArrowheadTypeEnum.kCircleArrowheadType
			dimension.SecondArrowheadType = ArrowheadTypeEnum.kCircleArrowheadType
Next
Tomasz Dąbrowski
Technical Support Specialist
Customer Technical Success
