Control Extrude direction through iLogic
I'm trying the extrude direction as 'kNegativeExtentDirection' and 'kSymmetricExtentDirection but it's not working properly.
Does anyone have any hints?
Below is my code:
Sub main()
Dim oDoc As PartDocument
 oDoc = ThisApplication.ActiveDocument
Dim oDef As PartComponentDefinition
 oDef = oDoc.ComponentDefinition
Dim oFace As Face
oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select the face.")
Dim ThickenDirection As New ArrayList
ThickenDirection.Add("Thicken Inward")
ThickenDirection.Add("Thicken Outward")
ThickenDirection.Add("Thicken both direction")
Dim oFaceColl As FaceCollection
 oFaceColl = ThisApplication.TransientObjects.CreateFaceCollection
oFaceColl.Add(oFace)
Dim oThicken As ThickenFeature
'Dim oExtrude As ExtrudeFeature
Direction = InputListBox("Thicken Direction", ThickenDirection, Direction, Title := "Thicken Direction", ListName := "Thicken Direction")
If Direction = "Thicken Inward" Then
	oThicken = oDef.Features.ThickenFeatures.Add(oFaceColl, "0.10 in",
kPositiveExtentDirection, kJoinOperation)
'oExtrude = oDef.Features.ExtrudeFeatures.AddByDistanceExtent( _
'oFaceColl, "0.10 in", kPositiveExtentDirection, kJoinOperation)
Else If Direction = "Thicken Outward" Then
kNegativeExtentDirection , kJoinOperation)
'oFaceColl, "0.10 in",kNegativeExtentDirection , kJoinOperation)
Else If Direction = "Thicken both direction" Then
	oThicken = oDef.Features.ThickenFeatures.Add(oFaceColl, "0.100 in",
PartFeatureExtentDirectionEnum.kSymmetricExtentDirection, kJoinOperation)
'oFaceColl, "0.10 in",kSymmetricExtentDirection , kJoinOperation)
End Sub
Sergio.D.Suárez
Hi, the code related to "Thicken" works correctly.
The asterisk parts of the extrusion (those that are as comments) do not work because you want to load a collection of faces as a profile. You cannot make an extrusion by selecting a face, you need a profile, a closed region of a sketch.
I hope this helps with your problem. Regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
yes,This is correct!
But my question is that 'kNegativeExtentDirection' and 'kSymmetricExtentDirection' not working properly. please ignore the commented code.!!!!
