Contour Flange offset direction
breinkemeyer
breinkemeyer
Is there a method or property in the contour flange feature or definition that controls the offset side of the flange?  I see it when I manually edit the flange, but don't see it in the API.
blandb
May want to try this in the iLogic forum, may get better results there?
Autodesk Certified Professional
blandb
scratch that wrong post, my apologies lol
JelteDeJong
I think you are looking for the "ExtentDirection" property. As an example run the following iLogic rule. Select the Contour Flange feature. And check that it's changing.
Dim f As ContourFlangeFeature = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFeatureFilter, "")
If (f.Definition.ExtentDirection = PartFeatureExtentDirectionEnum.kNegativeExtentDirection) Then
    f.Definition.ExtentDirection = PartFeatureExtentDirectionEnum.kPositiveExtentDirection
Else
Jelte de Jong
Blog: hjalte.nl - github.com
breinkemeyer
That did the trick, thanks!
Curtis_Waguespack
@kacper.suchomski , see example for this without the Pick selection.
hope that helps, Curtis
Dim oDoc As PartDocument = ThisDoc.Document
f = oDoc.ComponentDefinition.Features.Item("Contour Flange1")
Else
kacper.suchomski
Wow! Thanks!
I slightly modified the code because I wanted it to be dependent on the text parameter - Size - "Outer" / "Inner" / "Middle"
If Size = "Out" Then
Else If Size = "Inn" Then
Else
	f.Definition.ExtentDirection = PartFeatureExtentDirectionEnum.kSymmetricExtentDirection
This is to define how the handle size will be oriented in relation to the dimensions.
Kacper Suchomski
