Context Menu dropdown?
spencer
spencer
I'm trying to add a dropdown menu to my right-click menu but I'm at a loss.
I'm looking to take the "Laser, Mill, Sol's" commands and put them in a flyout menu exactly like the BOM Structure commands.
I thought it might have just been using the "AddButtonPopup" function but that throws an error when I tried to add an object collection of those 3 button definitions. Not sure that style button can't be added to the context menu of if I messed up the function somehow.
etaCAD
For former versions of Inventor this was not possible to add a dropdown in a context menu.
I think it is still not possible in newer versions.
Andreas
etaCAD
yuzeaa
Take a look at this post.
spencer
Still getting an error when I do it the way described in that post, happens when right-click and it tries to add the controls to the command bar. I even downloaded the .rar to look through that code and mine is functionally identical for all I can tell (My buttons are defined elsewhere and put into a 'contextButtons' list)
AddHandler m_inventorApplication.CommandManager.UserInputEvents.OnContextMenu,
            Sub(SelectionDevice As Inventor.SelectionDeviceEnum, AdditionalInfo As Inventor.NameValueMap, CommandBar As Inventor.CommandBar)
                If m_inventorApplication.ActiveDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
                    Dim SelectedEntities As SelectSet = m_inventorApplication.ActiveDocument.SelectSet
                    If SelectedEntities.Count > 0 Then
                        If TypeOf SelectedEntities(1) Is ComponentOccurrence Then
                            Dim CategoryButtons As CommandBar = m_inventorApplication.UserInterfaceManager.CommandBars.Add("Category", "CategoryCmd", CommandBarTypeEnum.kButtonPopupCommandBar)
                            CategoryButtons.Controls.AddButton(contextButtons("Laser"))
                            CategoryButtons.Controls.AddButton(contextButtons("Mill"))
                            CategoryButtons.Controls.AddButton(contextButtons("Sol's"))
                            CommandBar.Controls.AddPopup(CategoryButtons)
            End Sub
yuzeaa
you can't define commandbar with same internalname  everytime  rightclick.
Class ThisRule
	Dim contextButtons As New Dictionary(Of String,ButtonDefinition)
    Private CategoryButtons As CommandBar
	Sub main
        Dim oControls = ThisApplication.CommandManager.ControlDefinitions
		contextButtons.Add("Laser", oControls.AddButtonDefinition("Laser", "LaserCmd", CommandTypesEnum.kShapeEditCmdType))
		contextButtons.Add("Mill", oControls.AddButtonDefinition("Mill", "MillCmd", CommandTypesEnum.kShapeEditCmdType))
		contextButtons.Add("Sol's", oControls.AddButtonDefinition("Sol's", "Sol'sCmd", CommandTypesEnum.kShapeEditCmdType))
		CategoryButtons =ThisApplication.UserInterfaceManager.CommandBars.Add("Category", "CategoryCmd", CommandBarTypeEnum.kPopUpCommandBar)
        AddHandler ThisApplication.CommandManager.UserInputEvents.OnContextMenu, AddressOf OnContextMenu
	End Sub
	Private Sub OnContextMenu(SelectionDevice As SelectionDeviceEnum, AdditionalInfo As NameValueMap, CommandBar As CommandBar)
        If ThisApplication.ActiveDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
            Dim SelectedEntities As SelectSet = ThisApplication.ActiveDocument.SelectSet
    End Sub
End Class
spencer
Ah, didn't realize that was the case and it's working perfectly now, thanks.
