Context for Publications Inventor Presentation Document in API
Anton_Chernomazov
Message 1 of 8
Anton_Chernomazov
I have some Inventor Presentation Document. I want to do some customising through Inventor API with C#. PresentationDocument object contains Publications indexator which requires some Context as Object type. Autodesk developer help does not contain info about it. What entity I can use as Context?
Replies (7)
Message 2 of 8
JoãoASilva
@Anton_Chernomazov ,
I know nothing about Presentation Document thru the API.
Can this API Object Model (2020) help you somehow?
João Silva
Mechanical Engineer
Message 3 of 8
Anton_Chernomazov
Unfortunately InventorObjectModel.pdf have no information about Publications entities.
Message 4 of 8
mjkoushik
Has anyone found the context for the publication object?
Message 5 of 8
Bert_Bimmel
Here's how i got hold of the Publications-Object that Autodesk seems to be trying to hideaway:
Unfortunately it requires some user interaction to select something useful in the GUI prior to capturing the Publications-Object via the Document's select set.
I'd appreciate very much, if there wasn't the urge to use such tinkering to get what you actually want!
Message 6 of 8
g.georgiades
Use the browsernode to bypass the context. You can adapt it to C# for your addin/program.
https://forums.autodesk.com/t5/inventor-programming-ilogic/context-for-publication-inventor-presenta...
Message 7 of 8
Bert_Bimmel
Yes, using the Browser-Workaround to access objects, that Autodesk tries to render inaccessible works fine: I had that Idea before too to access the publication tweaks. Didn't see, that the parent node's native object is the same thing as the parent of my select set's item.
That's because my original object of desire was the storyboard, and trying to find my path up through the object catalog lead me to the approach described above.
So here's my original intention that I'm still struggling with:
I want to turn things "back to normal", i.e. get rid of this obnoxious storyboard and snapshot's storyboard-associativity. So far, i figured out, that presentations, that have been created with older versions of inventor, and are opened in Inventor 2020+ are converted into Snaphots whose StoryboardAssociative flag is set to "false".
I haven't yet found a button in the GUI which breaks this associativity from newly created Presentations/Snapshots. But fortunately you can do it using the API:
So, after done so, you end up with some schizphrenic browser that shows different things, wether the Snapshot with broken associativity is activated for editing or not:
So, after breaking the chain to that $%&§!-Storyboard, i'd like to get rid of it. Turn's out, I can't, but at least i'd like to flush it's content down the toilet to prevent me or other's to accidentially try to alter the wrong explosion paths.
Inside the GUI I can mark the Browsernodes and say "delete", and after that I am where I want to be: Orphaned, empty Storyboard, and free explosion paths in my now unbound Snapshot:
Bert_Bimmel_3-1697695453052.png &
-> I'm happy! 🙂
As this clicking-orgy is tedious and needs to be explained to everybody multiple times, i'd like to fully automate it.
Turns out, when I grab my PresentationsTweaks via their browsernode to call their "delete" method, I end up with an empty browser, but a still populated Storyboard:
So, how do i get rid of the storyboard's content? That's why i ended up trying to get hold of the storyboard-object by going through a horse's a55 to get to its mouth, to find somthing i can flush there, but apparently, the API is as messed up as the GUI. At least, there is nothing left, that i could flush:
Message 8 of 8
g.georgiades
I am seeing success by programmatically selecting all the tweaks in the active storyboard and using inventor command to delete them. (After you undo the associativity and no scene is active)
When you physically hit delete key, it calls AppDeleteCmd, not some TweakDelete command so there must be something under the hood that is different.
Side note while testing this: i found that using Publication.Storyboards.Add creates a new storyboard, but it is invisible to the user 🙂
	Dim doc As PresentationDocument = ThisApplication.ActiveDocument
	Dim pubs As New List(Of Publication) 'Essentially PresentationDocument.Publications
	Dim topnode = doc.BrowserPanes.Item("Model").TopNode
	For Each node As BrowserNode In topnode.BrowserNodes 'These are all the scene nodes
		If node.NativeObject IsNot Nothing AndAlso TypeOf node.NativeObject Is Publication Then
			pubs.Add(node.NativeObject)
	Next
	Dim activePub = pubs.First(Function(p) p.DisplayName = doc.ActiveScene.Name) 'Essentially PresentationDocument.ActivePublication
	Dim activeStoryBoard = activePub.ActiveStoryboard
	ThisDoc.Document.SelectSet.Clear()
	For Each twk In activeStoryBoard.Tweaks
		ThisDoc.Document.SelectSet.Select(twk)
	Next
	ThisApplication.CommandManager.ControlDefinitions.Item("AppDeleteCmd").Execute2(True)
