content file center components
Hello
I currently use derive part concept when generation an assembly. I fequently use the structural shapes from the content file centre in my designs. My question is.
Is there a way to export a sketch from a component an import it into the structural shape (eg equal angle) so if I have to steel plates "X" apart I can adjust the length of the equal angle with out going into the parameters to change it.
adam.nagy
Autodesk Support
Autodesk Support
Hi Dominic,
Are you asking how to do this programmatically?
Do you know already if it's possible to do through the UI?
In general you should be able to just Copy/Paste sketch contents between parts. So I would try that.
Cheers,
Adam Nagy
Autodesk Platform Services
Hello
I know you can copy and paste the sketch, however this does not make the component update when you change another. For example we design a side plate that has a SHS bolted perpendicular to it. The SHS has a flange welded to it, this flange has holes in it and is part of the SHS assembly, this flange is then bolted to the side plate. The holes for the side plate and flange need to be of the same pattern and the hole pattern is determined by what size SHS is used.
[cid:image002.jpg@01D1915A.95A6DD40]
As the SHS is a content file centre component I wanted to see how I can link (like derived part) the sketch to the other items. I have now found a work around by linking the dimension parameters from one sketch to another., this works perfectly but requires a little bit of extra time to make it work.
Regards
Dominic Tunnell OIEAust
Mechanical Design Draftsman
Technical Support
[cid:image004.jpg@01D1915D.1440EB80]
JOEST Australia Pty Ltd
Phone: 08 9358 3740
Direct: 08 9259 8316
Fax: 08 9358 3928
E-mail: dominic.tunnell@joest.com.au
Web: www.joest.com.au
NOTICE:
JOEST Australia Pty Ltd respects the privacy of individuals and strives to comply with all applicable legislation. This message may contain privileged or confidential information intended only for the use of the addressee named above. If you are not the intended recipient of this message, you are hereby notified that you must not disseminate, copy or take any action in reliance on it. All attachments are issued under copyright and must not be used for any purpose without written permission from the copyright owner. If you have received this message in error, please contact JOEST or the sender immediately. JOEST takes all care to prevent the transmission of viruses by using virus scanning software, but excludes all liability for viruses or similar in any messages or attachments.
Please consider the environment before printing this e-mail
