Content Centre Change Size
donald_leigh
Message 1 of 11
donald_leigh
I found the attached rule (Changed to suit my needs) via YouTube user “Automation With iLogic
The rule is working almost. How I want the rule to work is 1: Select Bolt Size, 2: Select Bolt Length based only on bolt size
When I select the Size, the next list box displays all the available sizes not only for the size selected. Eg, M6 might be 30 to 50, M8 might be 40 to 80, M10 might be 50 to 100. When I select M6 it returns lengths 30 to 100. when I want only 30 to 50 returned.
Anyone able to help me out.
Replies (10)
Message 2 of 11
A.Acheson
Hi @donald_leigh
In your second list before adding the cell value check the previous selected Size value is a value in it's column and row.
If Not List2.Contains(Val2) AndAlso Val1 = oRow.GetCellValue(sCol1)Then
   List2.Add(Val2)
Regards
Alan
Message 3 of 11
donald_leigh
thanks @A.Acheson
Message 4 of 11
donald_leigh
@A.Acheson, Any chance you can help again please? I would like to be able to return just 1 cell value based on a row and column value. not the whole column.
Eg. for a nut in the content center, I want to return the height of the nut (Found in the column) based on the size (Found on a row)
Cheers
Donald
Message 5 of 11
A.Acheson
Hi @donald_leigh
You can record the ContentTableRow index that you found a certain value on and then check the row index again of a specific column for the cell value.
Syntax
ContentTableRow.Index() As Long
Regards
Alan
Message 6 of 11
donald_leigh
Hi @A.Acheson, Again thanks for your help
I would class myself as an intermediate beginner with Ilogic. I have been looking at the ContentTableRow index but have not been able to get this working.
Could you offer any more help please.
Donald
Message 7 of 11
A.Acheson
Can you share the code your using and where you want to input your value?
If you have all the criteria in a logic then there should be only one row that matches the criteria you select.
Regards
Alan
Message 8 of 11
donald_leigh
Morning @A.Acheson.
I have attached the Ilogic rule that find all the available sizes of the nut in the CC. Once the size is selected I would like to be able to return the Thickness of the nut. This is referenced by the "KOH" parameter
Again, Thanks heaps for the help.
Donald
Message 9 of 11
A.Acheson
Hi @donald_leigh
You need to loop over the family rows again in order to get the row object of the size value selected. This is because you select the size after the first row loop and have no way to reference the row again.
iLogicVb.UpdateWhenDone = True
MultiValue.SetValueOptions(True, DefaultIndex := 0)
If NutType = "Plain Nut" Then
	NutChild = "Hex"
Else
	NutChild = "Locking Nuts"
'CC Family Name
	If Material = "Black (Plain)" Or Material = "Zinc Plated" Then
			NutTypeName = "HEX NUT"
	Else If Material = "G304" Or Material = "G316" Then
			NutTypeName = "HEX NUT - S/S"
Else
			NutTypeName = "HEX NYLOC NUT"
			NutTypeName = "HEX NYLOC NUT - S/S"
Components.ContentCenterLanguage = "en-US"
Dim oC As ContentCenter = ThisApplication.ContentCenter
Dim oCN As ContentTreeViewNode = oC.TreeViewTopNode
'CC Folders
oCN = oCN.ChildNodes.Item("Fasteners").ChildNodes.Item("Nuts").ChildNodes.Item(NutChild)
Dim oColumn As ContentTableColumn
Dim oRow As ContentTableRow
Dim oFam As ContentFamily
Dim oChosenFamily As ContentFamily
Dim FamName As String = NutTypeName
Dim sCol1 As String = "SIZE_SEL"
Dim sCol2 As String = "KOH"
Dim Val1 As String
Dim thick As String
Dim List1 As New ArrayList
For Each oFam In oCN.Families
	If oFam.DisplayName = FamName Then
		oChosenFamily = oFam
		For Each oRow In oFam.TableRows
			If Not List1.Contains(Val1) Then
				List1.Add(Val1)
		Next
Next
Val1 = InputListBox("Select " & sCol1, List1, "", "Content Center Part - " & FamName)
If Val1 = "" Then Return
MessageBox.Show(Val1, "Title")
For Each oRow In oChosenFamily.TableRows
	If oRow.GetCellValue(sCol1) = Val1 Then
			thick = oRow.GetCellValue(sCol2)
			Logger.Info("Index " & oRow.Index)
			Logger.Info(thick)
Next
'After Selecting the Nut Size I would like to be able to return the Thickness of that size Nut. This is referenced by the "KOH" parameter
	Dim Nut = Components.AddContentCenterPart("Nut",
    	                                      "Fasteners:Nuts:" & NutChild,
        	                                  NutTypeName,
            	                              {"Grade", "PC10", "Finish", Material, "SIZE_SEL", BoltSize})
Else
        	                                  NutTypeName,
            	                              {"Grade", Material, "SIZE_SEL", BoltSize })
Regards
Alan
Message 10 of 11
donald_leigh
Thanks Heaps @A.Acheson.
Where are you located?
Donald
Message 11 of 11
A.Acheson
No problem at all, I'm located in Vancouver.
Regards
Alan
