Content Center and Plates/Gussets
floccipier
floccipier
Hi all,
I have an elaborate rule that creates views for each frame generated part, I use these conditions to distinguish the frame generated parts:
If oPartDoc.ComponentDefinition.Document.PropertySets.PropertySetExists("ContentCenter") Then
If oPartDoc.ComponentDefinition.IsContentMember Then
'Do something
End if
Problem I'm facing is that all the plates/gussets that I bring into frame do bear these properties as well hence views for those plates are created as well which I don't want (I want these plates to go on separate sheets where I have all my sheet metal parts). Any idea how I can't achieve this?
A.Acheson
You can check the type of document you have, check the document is a sheetmetal part by checking  sub types.
Here are a sample of filters.
Dim doc As Document = ThisDoc.Document
If doc.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject  Then
'Drawing File
MessageBox.Show("Drawing", "Title")
Else If doc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject  Then
'Part & Sheet Metal File
    If ThisApplication.ActiveDocument.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" = True Then
        'Sheet Metal File
        MessageBox.Show("Sheet Metal", "Title")
    Else
        'Part File
        MessageBox.Show("Part", "Title")
Else If doc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject  Then
'Assembly File
MessageBox.Show("Assembly", "Title")
iLogicVb.UpdateWhenDone = True
 https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/find-sheet-metal-part-in-assembly/td-p/...
Regards
Alan
floccipier
@A.Acheson Thanks for your reply. I will test this later today.
