contact solve API
contact solve API
NemKumar
contact solve API
NemKumar
Is there any API for contact analysis feature like when two parts are in contact set, then if they collide, is there any event that gets raised.?
Thanks & Regards,
Vladimir.Ananyev
Could interference analysis help you?
http://forums.autodesk.com/t5/inventor-customization/contact-sets/m-p/2551162/highlight/true#M29720
Every InterferenceResult object could give you transient body representing the interference volume and both interfering components.
Inventor API contains “Interference Analysis API Sample” that demonstrates the functions used to calculate interference analysis in an assembly.
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
ekinsb
There isn't anything in the API for the contact solver except for access to the setting that's the equivalent to the UI document setting.  What Vladimir suggested is the only possible workaround that I can think of.  If you don't need real-time kind of interaction but if it can be more of a longer analysis it could probably work but it would take some time to implement.
Brian Ekins
Mod the Machine blog
NemKumar
Thanks guys,
I am using interferenceAnalysis and it works fine to some extent. What I want is when two parts come in contact, they should not move through each other. This behaviour is given well in contact solver. In case of InterferenceAnalysis, it just tells whether there is any collision or not. If I move one part through another part, it lets me to do that.
