Constrain, mate or flush? How to choose?
Hubert_Los
Hubert_Los
I would like to constrain the part to the origin plane at this actual position. I check the angle between the planes and if it is 0, I create a constraint. And at this point I have a problem, because I don't know what type of constraint I should choose. Sometimes the part rotates 180 degrees. Do you know how I can choose the constraints correctly?
Sub Constrain()
    Dim oADoc As AssemblyDocument
    Set oADoc = ThisApplication.ActiveDocument
    Dim oADef As AssemblyComponentDefinition
    Set oADef = oADoc.ComponentDefinition
    Dim oAsmYZPlane As WorkPlane
    Set oAsmYZPlane = oADef.WorkPlanes.Item(1)
    Dim oCompYZPlane1 As Object
    Dim oCompYZPlane2 As Object
    If oADoc.SelectSet.Count = 1 Then
        Set oOcc1 = ThisApplication.ActiveDocument.SelectSet.Item(1)
    Else
        Set oOcc1 = ThisApplication.CommandManager.Pick(kAssemblyLeafOccurrenceFilter, "1")
    Dim oCompPtDef1 As PartComponentDefinition
    Set oCompPtDef1 = oOcc1.Definition
    Call oOcc1.CreateGeometryProxy(oCompPtDef1.WorkPlanes.Item(1), oCompYZPlane1)
    Angle = ThisApplication.MeasureTools.GetAngle(oCompYZPlane1, oAsmYZPlane)
    If Angle = 0 Then
        Call oADef.Constraints.AddFlushConstraint(oCompYZPlane1, oAsmYZPlane, 0)
End Sub
Andrii_Humeniuk
Hi @Hubert_Los . You can check the direction of the plane normal if they are in the same direction to create the desired constraint. I added the following check on line 26:
Sub Constrain()
    Else
    If Angle = 0 Then
		If oAsmYZPlane.Plane.Normal.IsEqualTo(oCompYZPlane1.Plane.Normal, 0.001) Then
End Sub
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
