Hi Kurt,
I think what you would have to do is to arrange dimensions after the size of the part has changed. Unfortunately automatic arranging does not always give the desired result.
In some cases you may want to "mark" some dimensions with an attribute to avoid them to be automatically arranged.
I paste below the code I use for that.
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
Dim oDrawingDimension As DrawingDimension
Dim oDrawingDimensions As DrawingDimensions
Dim oDimsToBeArranged As ObjectCollection
Dim iLinearDimCount As Integer
Dim iAngularDimCount As Integer
Dim iOtherDimCount As Integer
iLinearDimCount = 0
iAngularDimCount = 0
iOtherDimCount = 0
' Iterate over all dimensions in the drawing and
' center them if they are linear or angular.
' Add them to the ObjectCollection to be arranged
oDrawingDimensions = oSheet.DrawingDimensions
oDimsToBeArranged = ThisApplication.TransientObjects.CreateObjectCollection
oDimsToBeArranged.Clear()
Dim oAttributeSets As AttributeSets
Dim oAttributeSet As AttributeSet
Dim oAttribute As Inventor.Attribute
'Dimensions with Arrange=False in CustomAttributeSet will not be arranged
For Each oDrawingDimension In oDrawingDimensions
'Get the AttributeSets
oAttributeSets=oDrawingDimension.AttributeSets
If oAttributeSets.NameIsUsed("CustomAttributeSet") Then 'if it has CustomAttributes
oAttributeSet = oAttributeSets.Item("CustomAttributeSet")
For Each oAttribute In oAttributeSet
If oAttribute.Name()="Arrange" Then
If oAttribute.Value = "False" Then
'Do nothing
Else
Select Case oDrawingDimension.Type
Case 117474560 ' kLinearGeneralDimensionObject
oDimsToBeArranged.Add(oDrawingDimension)
iLinearDimCount = iLinearDimCount+1
Case 117474816 'kAngularGeneralDimensionObject
' oDimsToBeArranged.Add(oDrawingDimension)
' iAngularDimCount = iAngularDimCount+1
Case Else
iOtherDimCount = iOtherDimCount +1
End Select
Else 'If the dimensions has a CustomAttributeSet but no Arrange attribute it must be arranged as default
Case Else
End Select
Next
Else 'If the dimensions has a CustomAttributeSet it must be arranged as default
Case Else
End Select
Next
Trace.Writeline("Linear dimensions = "& iLinearDimCount)
Trace.Writeline("Angular dimensions = "& iAngularDimCount)
Trace.Writeline("Other dimensions = "& iOtherDimCount)
oDrawingDimensions.Arrange(oDimsToBeArranged)
I hope this helps
