Constarining Axis in C#?
Dear All,
  I'm just learning to program Inventor, and I am a bit lost. Basically, I would like to do this:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/How-to-programmatically-constrain-two-...
 (i.e., take two object Z axes and contraint them to be the same), but in C#. In particular, what puzzles me is that I cannot make
'Get the Z-axis work axis from the occurrent.
Dim oPartAxis As WorkAxis
Set oPartAxis = oPartOcc.Definition.WorkAxes.Item(3)
 in C# because the Definition object has not a WorkAxes instance... I gues I need some casting done, but I do not know what... Any help woul dbe greatly appreciated!!!
  best
gus.-
nagwani
Hi Gus
The sample C# console application demonstrates the assembling (mate constraint) of two parts using work axes.
Hope this helps
-Ishwar N
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Inventor;
using System.Runtime.InteropServices;
namespace InventorConsole
    class Program
        static void Main(string[] args)
            // Get Inventor application
            Inventor.Application _app = null;
            _app = Marshal.GetActiveObject("Inventor.Application") as Inventor.Application   ;
            // Get active assembly document
            Inventor.AssemblyDocument aDoc = null;
            aDoc= _app.ActiveDocument as AssemblyDocument;
            // Get Assembly Component Definition
            Inventor.AssemblyComponentDefinition aCompDef = null;
            aCompDef = aDoc.ComponentDefinition as AssemblyComponentDefinition;
            // Get the occurrence to assemble
            Inventor.ComponentOccurrence aOcc1 = null;
            aOcc1 = aCompDef.Occurrences[1];
            Inventor.ComponentOccurrence aOcc2 = null;
            aOcc2 = aCompDef.Occurrences[2];
            // Get the Defition from occurrence
            Inventor.PartComponentDefinition pPartDef1 = null;
            pPartDef1 = aOcc1.Definition as PartComponentDefinition;
            Inventor.PartComponentDefinition pPartDef2 = null;
            pPartDef2 = aOcc2.Definition as PartComponentDefinition;
            // Get the z workaxis of both parts
            Inventor.WorkAxis pPartAxis1 = pPartDef1.WorkAxes[3];
            Inventor.WorkAxis pPartAxis2 = pPartDef2.WorkAxes[3];
            // Convert to Axes to assembly geometry proxy
            object axisProxy1 = null;
            Inventor.WorkAxisProxy pWorkAxisProxy1=null;
            aOcc1.CreateGeometryProxy(pPartAxis1, out axisProxy1);
            pWorkAxisProxy1 = axisProxy1 as WorkAxisProxy;
            object axisProxy2 = null;
            Inventor.WorkAxisProxy pWorkAxisProxy2 = null;
            aOcc2.CreateGeometryProxy(pPartAxis2, out axisProxy2 );
            pWorkAxisProxy2 = axisProxy2 as WorkAxisProxy;
            // Assemble parts
            aCompDef.Constraints.AddMateConstraint(pWorkAxisProxy1, pWorkAxisProxy2, 0.0);
            aDoc.Update();
Dear Ishwar,
  It worked!!!!
  THANKS A LOT!!!
  all the best
gus.-
