Message 1 of 1
Confusion on chaining "." operator to access methods/properties of objects
In the below code, I am trying to create a Vector2D object representing the vector between two Point2D objects.
In this example, I get an error about "Member not found".
Function IsChamferMatchedToSymbol(oChamferNote As ChamferNote,
oSketchedSymbol As SketchedSymbol) As Boolean
Dim oVector2D As Vector2D
oVector2D = oChamferNote.Position.VectorTo(oSketchedSymbol.Position)
In trying to figure out the above error, I tried splitting up the operations, which works properly:
Dim oChamferPoint2D As Point2D
Dim oSymbolPoint2D As Point2D
oChamferPoint2D = oChamferNote.Position
oSymbolPoint2D = oSketchedSymbol.Position
oVector2D = oChamferPoint2D.VectorTo(oSymbolPoint2D)
In my mind, I should be able to chain the results together from the "." operator, into a single line (line 5, 1st example). Can someone help explain why this results in an error?
@bbrownellLS4J4
