Configure colors in stress analysis
Hey
First of all, I'm currently using Inventor 2014 Professional Edition, and heres my problem:
I've got an assembly, which I'm running some momentum stress analysing on. Which is all good, until it shows the results, I've got some very small local spots reaching far more MPa than intended, which is obvious since theres supposed to be a welding and so on, then the question is;
My color bar is going from 0 to 385MPa, but I would like it to only show between 0-150MPa areas where 150MPa wont appear marked as red.
Cause if I set the max from the Color Bar icon it will fine show 0-150MPa areas, but the 150 ones are brutally red.
I hope you understand what I'm asking for, otherwise feel free to ask 🙂
I cant attach a screenshot at the moment, since my laptop is currently running an analysis
Heres a picture of the color bar setting, hope someone can tell me why the 'plus' and 'minus' are grayed out? 🙂
Forgot the picture it seems.
