Conditional Formatting of Revision Table
youann21700
youann21700
I am trying to improve the formatting of our revision tables. For drawings not issues for manufacture or use of material sourcing, we use letter revisions (i.e. A, B, C etc), once drawings are released to clients, we use revisions numbers from 0.
Once the switch is made, I want to hide the letter revision rows. I have attached the snippet of code i am using,
		Dim oRevTable As RevisionTable
									Try
										oRevTable = ThisDoc.Document.ActiveSheet.RevisionTables.Item(1)
									Catch
										oRevTable = ThisDoc.Document.Sheets.Item(1).RevisionTables.Item(1)
									End Try
									Dim oRows As RevisionTableRows = oRevTable.RevisionTableRows
									oRevRowCount = oRevTable.RevisionTableRows.Count
									For i = 1 To oRevRowCount
										Dim oCell As RevisionTableCell = oRevTable.RevisionTableRows.Item(i).Item(1)
										Dim oCellCont As String = oCell.ToString
										If IsNumeric(oCellCont) = False
											oRows(i).Visible = False
											Else
												oRows(i).Visible = True
									Next
 it does not seem to differentiate between numeric and non-numeric revision labels. When the snippet is run, both rows in the picture below are made invisible.
jnowel
change your oCellCont definition as oCell is still a RevisionTableCell Object and not the text value it contains
Dim oCellCont As String = oCell.Text
