Components Not Visible When Using Tube and Pipe Add-In
Message 1 of 1
Hello all,
I need help!  In previous release of Inventor, I have used the tube and pipe add-in when creating flexible hoses to represent voltage wiring.  In the past, I have been able to reference the components in my assembly as points to run the wire.  With the latest release that I have, turns off all visibility on the other components within the assembly.  Is there a way to turn these components on again?  As it is right now, I have no way to create a route going from one component to another.
Replies (0)
