Components.Add + rotate
I can get the Components.Add command to bring in parts, but how on Earth do I set the rotation of them?
I've been doing it the really long matrix way in the past but I hoped this would be quicker.
tobias.orlow
Hi @Anonymous ,
one thing you could give a try is executing the commands from the radial menu by calling them explicitly (names below).
"AssemblyPlaceCompRotateX90Cmd" Rotate X 90°
"AssemblyPlaceCompRotateY90Cmd" Rotate Y 90°
"AssemblyPlaceCompRotateZ90Cmd" Rotate Z 90°
Please refer to the following article for how to run commands via API:
https://modthemachine.typepad.com/my_weblog/2009/03/running-commands-using-the-api.html
Please let me know if this works for you, I will also do some testing on my end.
Thank you!
Tobias
Tobias Orlow
Designated Support Specialist
Customer Success Organization
Linkedin: www.linkedin.com/in/tobiasorlow/
