Component Library download.
Message 1 of 15
Where can i find a standart componets library for inventor 2015?
I can't download free Vault, because a'm a student
And i find this:
https://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/autodesk-i...
But it requires an autodesk data manager server been installed
I didn't find it on autodesk.com too
So what to do?
Replies (14)
Message 2 of 15
Jef_E
This has nothing to do with vault, did you deselect the content centers during the install? The content center files are installed along with inventor.
And you should check your application options if the location is set correctly.
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Message 3 of 15
I have got this (but it do nothig, when i try to install it now(!))
Message 4 of 15
Mark.Lancaster
You need to run the setup (setup.exe) of your Inventor installation again.  Then when you get to the list of applications being installed scroll down and find content center.
Also in the future this type of question should be posted in the Inventor general discussion group or the Autodesk Installation and licensing one.
Mark Lancaster
Message 5 of 15
I reinstalled inventor 2015. It bring no results. There were no possibility to deselect something.
Also i checked the way to library (C:\ProgramData\Autodesk\Inventor 2015\Content Center\Libraries)
And files of library are there, but inventor doesn't see them during work (screen 13)
Message 6 of 15
I reinstalled, but there is no Library options in there.
And the Library installator isn't launching (!?)
Where can i find a correct Library installator?
Message 7 of 15
Mark.Lancaster
Based on your image you have the desktop content center libraries installed already.  In Inventor under Tools/Application Options/Content center..  What is it set to:
Desktop or Vault Server.
If desktop what is the path set to?
Mark Lancaster
Message 8 of 15
Yeah, it's all the same (screen19)
What can i do now?
Message 9 of 15
Mark.Lancaster
So what happens when you place from content center in your assemby?  Is it blank?
Also in your active Inventor project file, select the lower icon and are the libraries selected?
Mark Lancaster
Message 10 of 15
Inventor 2015 doesn't see the files from correct (C:\ProgramData\Autodesk\Inventor 2015\Content Center\Libraries) way (screen 20)
I can't choose anything because of it (screen 21)
Message 11 of 15
Mark.Lancaster
I just went back to your original image showing the libraries (in windows explorer) and now realize you don't have the desktop libraries installed.  Their file extension needs to be .idcl.   Do you still have access to the media you used to install your Inventor?  If so run the setup.exe from there.  Do not use an exe that maybe in that location where your libraries are stored.
Mark Lancaster
Message 12 of 15
It's strange, but i have it in the list of installed programms (screen 22)
Message 13 of 15
And it's all repeats (screen 23)
I just tried to reinstall it and now it requires me to have Autodesk Data Management Server... is it Vault?
Message 14 of 15
Mark.Lancaster
Did I ever say launch contentlibrarysetup.exe?  No I said launch setup.exe from your Inventor original installation media...  Don't go looking for any other exe.   In addition I have never seen content center library listed in installed programs.   You are running all these different exe that are not necessay.  If you just run the original setup.exe in your orignal Inventor media you can get this resolved in a matter of minutes..
Mark Lancaster
Message 15 of 15
One more
Maybe the problem was because of the absent panel from the left (screen 25)
I reinstalled like you sad
And now it's ok!
Thanks a lot!
