Component.Isavtive vs Feature.Isactive
Message 1 of 11
I am struggling with the terms "Component.Isactive" and "Feature.Isactive". If I have an assembly (* .iam) with a Pattern in it, is this a "Component" or a "Feature"? And how is this if this is in a part (* .ipt)? Hopefully someone has an explanation for this so that I understand where I make mistakes.
Thank you, Joop
Replies (10)
Message 2 of 11
bhavik4244
@Anonymous
If you're trying to control features in the part file (.ipt) or in assembly (.iam) then you should go for, (whether it's a pattern or features, it'll work for both)
'To unsuppress the feature
Feature
.IsActive("NameOfthefeature") = True
'To suppress the feature
Feature.IsActive("NameOfthefeature") = False
 If you're trying to control components state in the assembly file (.iam) then you should go for, (whether it's a pattern or parts, it'll work for both)
'to suppress the component
component
.IsActive("nameOftheOccurance") = False
'to unsuppress the component
component.IsActive("nameOftheOccurance") = True
Bhavik Suthar
Message 3 of 11
dutt.thakar
@Anonymous
Whenever you are inside and part file(.ipt), the only thing you can use is Feature.IsActive. The reason is that inside an ipt file, whatever you are creating is using features (e.g Extrude, Revolve, Hole, Fillet, etc.) No Component.IsActive is applicable when you are inside an ipt file.
For Assembly files (iam), You can also create features (Extrude, Revolve, Hole, etc.) inside it and then use part files(ipt) to place and constraint it. Now when you are targetting features, you need to use Feature.IsActive in assembly, but when you are targetting components (ipt or iam files), you need to use Component.IsActive.
Now In the case of patterns inside the assembly, please note that if you are creating a pattern of Features (e.g. Extrude, Revolve, Hole, etc.) you need to use Features.IsActive to either suppress or unsuppress. On the other hand, if you are creating a pattern of Components (ipt or iam files), you need to use Component.IsActive.
I hope this has cleared the confusion.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
Message 4 of 11
Thank you for the explanation.
But how can I turn on and off a retagular pattern in an assembly (* .iam)? I have created a user parameter for number and a user parameter for distance. But now I have problems with controlling this, because I thought I had written a good code anyway
Message 5 of 11
bhavik4244
@Anonymous
Can you post your code here? it would give more insight where could be the issue
Bhavik Suthar
Message 6 of 11
i
Select Case DraairichtingPoort
Case "DIN Links"
'Suppressen onderdelen aanslag Din Rechts
Component.IsActive("1043_977:2") = False
Component.IsActive("1013_456:2") = False
Component.IsActive("ComponentPatternDinRechts") = False
Component.IsActive("1013_453:2") = False
'UNSuppressen onderdelen aanslag Din Links
Component.IsActive("1043_977_22") = True
Component.IsActive("1013_456_23") = True
Component.IsActive("ComponentPatternDinLinks") = True
Component.IsActive("1013_453_26") = True
PlaatOfPlankDikte = PlankOfPlaatVoorkant
Case "DIN Rechts"
'Suppressen onderdelen aanslag Din Links
Component.IsActive("1043_977_22") = False
Component.IsActive("1013_456_23") = False
Component.IsActive("ComponentPatternDinLinks") = False
Component.IsActive("1013_453_26") = False
'UNSuppressen onderdelen aanslag Din Rechts
Component.IsActive("1043_977:2") = True
Component.IsActive("1013_456:2") = True
Component.IsActive("ComponentPatternDinRechts") = True
Component.IsActive("1013_453:2") = True
PlaatOfPlankDikte = PlankOfPlaatAchterkant
'Updaten rule
Parameter.UpdateAfterChange = True
RuleParametersOutput()
InventorVb.DocumentUpdate()
iLogicVb.UpdateWhenDone = True
End Select
Select Case Slotkeuze
Case Fortylock
AantalBlokkenSlot = 0 ul
Case Fiftylock
AantalBlokkenSlot = 1 ul
Case Sixtylock
AantalBlokkenSlot = 2 ul
End Select
'Array Din Links
ArrayBlokkenDinLinks = (AantalBlokkenSlot + ArrayBlokkenPlaat)
'Array Din Rechts
ArrayBlokkenDinRechts = (AantalBlokkenSlot + ArrayBlokkenPlaat)
'Bepalen som van aantal affstandsblokken bij Din Rechts
If ArrayBlokkenDinRechts = 0 Then
AfstandAanslagDinRechts = 0
Else
AfstandAanslagDinRechts = (ArrayBlokkenDinRechts* DikteAfstandblok)
iLogicVb.DocumentUpdate
'Bepalen som van aantal affstandsblokken bij Din Links
If ArrayBlokkenDinLinks = 0 Then
AfstandAanslagDinLinks = 0
Else
AfstandAanslagDinLinks = (ArrayBlokkenDinLinks * DikteAfstandblok)
'Bepaling benodigde afstandsblokken ivm plank of plaat
''' Bepaling van de benodigd aantal opvulblokken in verband met plaat of planken op de poortvleugel
''' Deze code is UNIVERSEEL, de draairichting bepaald welke parameter wordt toegepast
''' DIN Links dan wordt PlaatOfPlankDikteVoorkant gebruikt
''' DIN Rechts dan wordt PlaatOfPlankDikteVoorkant gebruikt
Dim Dikte As Double
Dikte = PlaatOfPlankDikte
If Dikte = 0 Then
ArrayBlokkenPlaat = 0 ul
Else If Dikte > 1 And Dikte <= 5 Then
ArrayBlokkenPlaat = 1 ul
Else If Dikte > 5 And Dikte <= 10 Then
ArrayBlokkenPlaat = 2 ul
Else If Dikte >10 And Dikte <= 15 Then
ArrayBlokkenPlaat = 3 ul
Else If Dikte > 15 And Dikte <= 20 Then
ArrayBlokkenPlaat = 4 ul
MessageBox.Show("Indien nodig ter hoogte van tegensluiting uitsparing maken in plaat of plank!", "Melding")
Else If Dikte > 20 Then
MessageBox.Show("De afstand hart frame tot aan aanslag tegensluiting is te groot! Plaat of planken ter hoogte van tegensluiting uitsparen!", "Melding")
Message 7 of 11
bhavik4244
@Anonymous
Try this as a new rule,
If DraairichtingPoort = "DIN Links" Or ArrayBlokkenDinRechts = 0
Else If DraairichtingPoort = "DIN Rechts" Or ArrayBlokkenDinRechts <> 0
Bhavik Suthar
Message 8 of 11
WCrihfield
It looks like you are trying to use Component.IsActive() to turn component patterns on/off.  That is probably where the problem is.  I don't think that is possible.  You may have to suppress that pattern object, or loop through all possible sub-patterns and suppress (or set visibility to off) for each component within.
OccurrencePatterns Object
OccurrencePatterns.AddRectangularPattern Method
RectangularOccurrencePattern Object
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
Message 9 of 11
@bhavik4244
thanks for the code, do i have to change the code i posted? or does this new rule jusst added?
Message 10 of 11
bhavik4244
@Anonymous
As long as it serves your purpose make it a new rule 🙂
Bhavik Suthar
Message 11 of 11
Whoop, Whoop, It works!!!!!
Thank you all!
Next step changing Description in Bill of Materials.......
