Component.IsActive inside for each loop
sigurdurie
Message 1 of 13
sigurdurie
Hi
I'm trying to check wether a component is active i.e. not suppressed in a for each loop to get the DXF if and only if the part is active in the assembly.
I've tried just about anything but without any success.
The rule is as follows:
question = MessageBox.Show("Do you want to save to DXF?", "iLogic Question",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
'set condition based on answer
If question = vbYes Then
	' ==============================* Get DXF *====================================
	DXF_LOC = ThisDoc.Path & "\DXF\"
	Dim asmDoc As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oDoc As Inventor.Document
	For Each oDoc In asmDoc.AllReferencedDocuments
		If Not oDoc.DocumentSubType.DocumentSubTypeID = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Continue For
		 oDocName = oDoc.Displayname
		' If component is Active proceed
			If iProperties.Value(oDocName ,"Summary", "Keywords") = "ISM" Then
				Dim oCompDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition
				' Check if part has flat pattern, create if not
				If Not oCompDef.HasFlatPattern Then
					oCompDef.Unfold
					oDoc.Save
					oDoc.Close
				' DXF config
				Dim sOut As String = "FLAT PATTERN DXF?" _
				+ "AcadVersion=2004" _
				+ "&OuterProfileLayer=IV_OUTER_PROFILE:Visibility=ON;LinePattern=28100;LineWeight=0,0500;Color=0,128,0;" _
				+ "&InvisibleLayers=IV_TANGENT;IV_BEND;IV_BEND_DOWN;IV_ROLL_TANGENT;IV_ARC_CENTERS"
				Dim sFname As String = ""
				Select Case oDocName
					Case "HB132.ipt":          	sFname = "IF-H-LAMIR-" & FVG & "-" & Parameter("HB132:1", "Lengd") & "X" & Parameter("HB132:1", "Breidd")
					Case "HB133.ipt":          	sFname = "IF-H-LASINN-" & FVG & "-" & Parameter("HB133:1", "Lengd") & "X" & Parameter("HB133:1", "Breidd")
					Case "IFK-YFIRSTYKKI.ipt": 	sFname = "IFK-YFIRSTYKKI-" & Parameter("IFK-YFIRSTYKKI:1", "Lengd") & "X" & Parameter("IFK-YFIRSTYKKI:1", "Breidd")
					Case "PANNA-H.ipt":        	sFname = "PANNA-H-" & Parameter("PANNA-H:1", "Lengd") & "X" & Parameter("PANNA-H:1", "Breidd")
					Case "BYRÐI-H.ipt":        	sFname = "BYRDI-" & BNFP & "-H-" & Parameter("BYRÐI-H:1", "Lengd") & "X" & Parameter("BYRÐI-H:1", "Breidd")
					Case "Skuffa-LL.ipt":           sFname = "SKUFFA-LL-" & Parameter("Skuffa-LL:1", "Lengd") & "X" & Parameter("Skuffa-LL:1", "Breidd")
					Case "Thr-Profill.ipt":		sFname = "Thr-Profill-" & Parameter("Thr-Profill:1", "Lengd") & "X" & Parameter("Thr-Profill:1", "Breidd")
					Case Else:                 ' Halda áfram
				End Select
				If sFname <> vbNullString Then
					oCompDef.DataIO.WriteDataToFile(sOut, DXF_LOC & sFname & ".dxf")
		' End If
	Next
	'Component.IsActive("Skuffa-LL:1") = 0
	RuleParametersOutput()
	InventorVb.DocumentUpdate()
Else
	' Nothing
I have no idea how or what to use to get the IsActive to work. I've been trying to find answers here and elsewere and tried to adjust what I have found to my specific problem without success.
How do I go from a document to an occurrence in the assembly: HB132.ipt -> HB132:1
Is there a simple way to do this?
Replies (12)
Message 2 of 13
Owner2229
Hi, the code you're currently ussing is going through every document reference (one per open assembly and subassemblies) instead of component occurrence (many times per assembly) in order to make it run faster. In case your assemblies have many occurrences per part, the current code would run faster. However if you have many subassemblies suppresed and in these are parts that doesn't occurre in other assemblies, the occurrence-way code might run faster. In the end, you can test both and see. Here is the occurrence-way:
Red-highlighted is what I've changed.
Sub Main()
question = MessageBox.Show("Do you want to save to DXF?", "iLogic Question",MessageBoxButtons.YesNo,MessageBoxIcon.Question) ' Set condition based on answer If Not question = vbYes Then Exit Sub
GoThroughOccs(asmDoc)
End Sub
Private DXF_LOC As String
Sub GoThroughOccs(asmDoc As AssemblyDocument) ' ==============================* Get DXF *==================================== Dim oOcc As ComponentOccurrence For Each oOcc In asmDoc.ComponentDefinition.Occurrences
If Not oOcc.IsActive Then Continue For
Dim oDoc As Inventor.Document = oOcc.Definition.Document
If oDoc.DocumentType.ToString = "kAssemblyDocumentObject" Then GoThroughOccs(oDoc) If Not oDoc.DocumentSubType.DocumentSubTypeID = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Continue For Dim oDocName As String = oDoc.Displayname If iProperties.Value(oDocName ,"Summary", "Keywords") <> "ISM" Then Continue For Dim oCompDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition ' Check if part has flat pattern, create if not If Not oCompDef.HasFlatPattern Then oCompDef.Unfold oDoc.Save oDoc.Close End If ' DXF config Dim sOut As String = "FLAT PATTERN DXF?" _ + "AcadVersion=2004" _ + "&OuterProfileLayer=IV_OUTER_PROFILE:Visibility=ON;LinePattern=28100;LineWeight=0,0500;Color=0,128,0;" _ + "&InvisibleLayers=IV_TANGENT;IV_BEND;IV_BEND_DOWN;IV_ROLL_TANGENT;IV_ARC_CENTERS" Dim sFname As String = "" Select Case oDocName Case "HB132.ipt": sFname = "IF-H-LAMIR-" & FVG & "-" & Parameter("HB132:1", "Lengd") & "X" & Parameter("HB132:1", "Breidd") Case "HB133.ipt": sFname = "IF-H-LASINN-" & FVG & "-" & Parameter("HB133:1", "Lengd") & "X" & Parameter("HB133:1", "Breidd") Case "IFK-YFIRSTYKKI.ipt": sFname = "IFK-YFIRSTYKKI-" & Parameter("IFK-YFIRSTYKKI:1", "Lengd") & "X" & Parameter("IFK-YFIRSTYKKI:1", "Breidd") Case "PANNA-H.ipt": sFname = "PANNA-H-" & Parameter("PANNA-H:1", "Lengd") & "X" & Parameter("PANNA-H:1", "Breidd") Case "BYRÐI-H.ipt": sFname = "BYRDI-" & BNFP & "-H-" & Parameter("BYRÐI-H:1", "Lengd") & "X" & Parameter("BYRÐI-H:1", "Breidd") Case "Skuffa-LL.ipt": sFname = "SKUFFA-LL-" & Parameter("Skuffa-LL:1", "Lengd") & "X" & Parameter("Skuffa-LL:1", "Breidd") Case "Thr-Profill.ipt": sFname = "Thr-Profill-" & Parameter("Thr-Profill:1", "Lengd") & "X" & Parameter("Thr-Profill:1", "Breidd") Case Else: ' Halda áfram End Select If sFname <> vbNullString Then oCompDef.DataIO.WriteDataToFile(sOut, DXF_LOC & sFname & ".dxf") End If Next End Sub
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 3 of 13
sigurdurie
Thank you for the response
I'm getting an error probably because I had to change it a little. I put everything before the save to DXF to sub Main() there can be only one sub main like this:
Sub Main()
   ' Configure and build the door and then ask if user wants to save to DXF
' (About 200 lines of code for this type of door, more doors to come) question = MessageBox.Show("Do you want to save to DXF?", "iLogic Question",MessageBoxButtons.YesNo,MessageBoxIcon.Question) ' Set condition based on answer If question = vbYes Then SaveToDXF() Else ' Nothing End If End Sub
Sub SaveToDXF()
End Sub
                    oCompDef.Unfold
                    oDoc.Save
                    oDoc.Close
        ' DXF config
            Case "BYRDI-H.ipt":            sFname = "BYRDI-" & BNFP & "-H-" & Parameter("BYRDI-H:1", "Lengd") & "X" & Parameter("BYR�I-H:1", "Breidd")
            Case Else:                     ' Continue (more cases to come)
        End Select
    Next
End Sub
But this returns an error for the IsActive:
More info:
Something about public and private members. I tried to omit the sub main() and other call to function but got a similar error on the IsActive.
Message 4 of 13
sigurdurie
By changing the line:
To:
If Not Component.IsActive(oOcc.Name) Then Continue For
I stop getting the error but no DXF is returned to the DXF folder.
Message 5 of 13
Owner2229
Hi, sorry, I've overseen this one. Try this instead:
If oOcc.Suppresed Then Continue For
Mike
Message 6 of 13
sigurdurie
Same result -> No error but nothing turnes up in the DXF folder
I have confirmed that the path is ok by printing out the DXF_LOC so at least that is working. But nothing gets printed after the if statement no matter how it is formed.
Message 7 of 13
Owner2229
Alright, Let's try it once again:
Btw.: I've tested it and it works for me.
Sub Main()
End Sub
                If oOcc.Suppressed Then Continue For
			oCompDef.Unfold
oCompDef.FlatPattern.ExitEdit oDoc.Save oDoc.Close End If ' DXF config Dim sOut As String = "FLAT PATTERN DXF?" _ + "AcadVersion=2004" _ + "&OuterProfileLayer=IV_OUTER_PROFILE:Visibility=ON;LinePattern=28100;LineWeight=0,0500;Color=0,128,0;" _ + "&InvisibleLayers=IV_TANGENT;IV_BEND;IV_BEND_DOWN;IV_ROLL_TANGENT;IV_ARC_CENTERS" Dim sFname As String = "" Select Case oDocName Case "HB132.ipt": sFname = "IF-H-LAMIR-" & FVG & "-" & Parameter("HB132:1", "Lengd") & "X" & Parameter("HB132:1", "Breidd") Case "HB133.ipt": sFname = "IF-H-LASINN-" & FVG & "-" & Parameter("HB133:1", "Lengd") & "X" & Parameter("HB133:1", "Breidd") Case "IFK-YFIRSTYKKI.ipt": sFname = "IFK-YFIRSTYKKI-" & Parameter("IFK-YFIRSTYKKI:1", "Lengd") & "X" & Parameter("IFK-YFIRSTYKKI:1", "Breidd") Case "PANNA-H.ipt": sFname = "PANNA-H-" & Parameter("PANNA-H:1", "Lengd") & "X" & Parameter("PANNA-H:1", "Breidd") Case "BYRÐI-H.ipt": sFname = "BYRDI-" & BNFP & "-H-" & Parameter("BYRÐI-H:1", "Lengd") & "X" & Parameter("BYRÐI-H:1", "Breidd") Case "Skuffa-LL.ipt": sFname = "SKUFFA-LL-" & Parameter("Skuffa-LL:1", "Lengd") & "X" & Parameter("Skuffa-LL:1", "Breidd") Case "Thr-Profill.ipt": sFname = "Thr-Profill-" & Parameter("Thr-Profill:1", "Lengd") & "X" & Parameter("Thr-Profill:1", "Breidd") Case Else: sFname = Left(oDocName, Len(oDocName) - 4) End Select If sFname <> vbNullString Then oCompDef.DataIO.WriteDataToFile(sOut, DXF_LOC & sFname & ".dxf") End If Next End Sub
Mike
Message 8 of 13
sigurdurie
Ok, some progress I actually get further than I initially thought.
I get all the way to this line:
SyntaxEditor Code Snippet
after that nothing gets printed.
Message 9 of 13
sigurdurie
sFname is always a nullstring, I think that is because oDoc does not look at sub assemblies?
Message 10 of 13
Owner2229
Well, yea...
I have no idea why do you have it there in the first place...
It is looking for a value "ISM" in the iProperty "Keywords" (should be "Kulcsszavak" in Hungarian) and skips this document if it can't find it.
If you have put it there unintentionaly, then you can remove it or comment it out.
Mike
Message 11 of 13
sigurdurie
This line is actually to ensure I only get the parts that I need for the punching machine, everything else does not matter.
ISM -> Is Sheet Metal
Could be anything: PM for punching machine for instance
It's just a way to try to get only these parts to the DXF folder
Message 12 of 13
sigurdurie
It's there intentionally, it's a way to ensure I only get the parts I need to the DXF folder.
I could have used PM (Punching Machine) for instance
I only need these parts saved as DXF other sheet metal parts are not needed for the punching machine on a day to day bases. They are batch produced and are always the same.
Message 13 of 13
sigurdurie
Solved 🙂
With a little tweaking I managed to get exactly what I was looking for with your help.
Thank you wery much for your time and effort it's highly appreciated.
Ended with omitting the iProperties out and used this instead:
Select Case oOcc.Name
			Case "HB132:1":
