Component Invisibility in Drawing Macro Trouble
All,
I am working on a macro to try and make certain components invisible in a drawing view and am having a hangup with the code I am posting below. As I test the code I find that I can cause components to be suppressed, but cannot change their visibility. I have had success with this basic code on assemblies, but am having some trouble with the drawing files.
Can someone please point me in the right direction? Thanks and have a great day!
Public Sub Inventor_Automatic_Component_Invisibility()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Set oSheet = oDoc.ActiveSheet
Dim oAssyDoc As AssemblyDocument
Set oAssyDoc = oSheet.DrawingViews(1).ReferencedDocumentDescriptor.ReferencedDocument
Dim oCompDef As Inventor.ComponentDefinition
Set oCompDef = oAssyDoc.ComponentDefinition
Dim oComponent As ComponentOccurrence
For Each oComponent In oCompDef.Occurrences
Select Case oComponent.Name
Case "Part1"
oComponent.Suppress
Case "Part2"
oComponent.Visible = False
Case "Part3"
oComponent.Suppress
End Select
Next
End Sub
You have to set the visibility using the DrawingView like so:
DrawingView.SetVisibiliy(oComponent, true)'or false
You might have to assign the DrawingView to a variable first, I
haven't actually tried this, but I was looking for something in the
past where I could do both visibility and turn on/off hidden line
mode on an occurence. I gave up when I found out that the API still
doesn't support the hidden line option. Should work for visiblity
though. You can lookup the DrawingView.SetVisibilty method in the
API docs.
Bob S.
On 2010/06/01 2:38 PM, puertoricanpete wrote:
> All,
> Dim oSheet As Sheet
> Case "Part1"
> oComponent.Suppress
> Case "Part2"
> Case "Part3"
> oComponent.Suppress
> End Select
> Next
> End Sub
Bob, I guess I am having some trouble with this. Could you please put in a line of code to make sure I am using your suggestion correctly? I would really appreciate it. Thanks for the tip and I'll keep plugging away.
I have posted the modified code below, after taking into account Bob's suggestion. However, I am not getting a run time error '-2147467259 (80004005)', that states:
"Method 'SetVisibility' of object 'DrawingView' failed
Can anyone dissect what I have done and offer some advice or better application of the principal?
Dim oDoc As Inventor.DrawingDocument
Dim oSheet As Sheet
Dim oViewDef As DrawingView
Set oViewDef = oSheet.DrawingViews(1)
Case "Part1"
oViewDef.SetVisibility oComponent, False
End Select
Next
End Sub
YuhanZhang
The failure occurs when you are trying to suppress the last visible component. You can add an Error handler(like On Error Resume Next) to go pass this failure.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Thanks for the help. That fixed up the trouble. In fact, thanks to everyone, as the macro is working great!
