Compiling error: Can't copy stdole.dll into bin folder
wowrs1608
wowrs1608
I am trying to compile an old vb.net code. I got a compiling error saying MS shared file stdole.dll can't be copied into Inventor 2013\bin folder. I am now using 2022\bin.
Which type file in the vb.net project files I could change the folder to 2022?
And I saw there is already a stdole.dll file under bin folder. Why it still ask to copy into one?
Thanks for help.
Regards.
Pete
jatindevaiya08
As I understand there is no need to copy stdole.dll file in compilation. Change Embed Interop Types to True. For me it's work fine with this.
Jatin Devaiya
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
wowrs1608
Thanks. Now the error is from a Call to mt.exe.
Maybe I need to change The vsvars32 to 64 bit version? I tried to run mt.exe inside a folder in a DOS window , It can't find mt.exe.
jatindevaiya08
@wowrs1608  If it's in Post-built event then you can remove that and add below code. and remove anything in Pre-Built event.
REM - Set up the environment.
call "%VS150COMNTOOLS%\VsDevCmd"
REM - Embed the manifest into the dll.
mt.exe -manifest "$(ProjectDir)$(TargetName).X.manifest" -outputresource:"$(TargetPath)";#2
REM - Copy the .addin file and the ButtonResources folder into the result folder.
XCopy "$(ProjectDir)Autodesk.$(TargetName).Inventor.addin" "$(TargetDir)" /y
XCopy "$(ProjectDir)ButtonResources" "$(TargetDir)ButtonResources" /y /r /i /s /f
REM - Delete the pdb file because it doesn't need to be delivered.
DEL "$(TargetDir)$(TargetName).pdb"
REM - Delete the existing add-in folder.
rmdir /q /s "C:\ProgramData\Autodesk\Inventor Addins\$(TargetName)"
REM - Copy the folder to the Inventor Addins folder so Inventor will see it and run it.
XCopy "$(TargetDir)*" "%appdata%\Autodesk\ApplicationPlugins\$(TargetName)\" /y /r /i /s /f
Accept this as a solution.
Jatin Devaiya
wowrs1608
After adding the path of mt.exe into Window's Path, now I can build again.
Thank you very much.
