Compare contraints values states model
vianney_cheneau
Message 1 of 1
vianney_cheneau
I am happy to share this ilogic rule
Frist the rule show if the constraint if hideen on each model states
then it compare the value of each contraint and show if value if different beteween the model states
and you can also hide the lines with the same value
Typicaly, this rule was made if you forgot to check or uncheck the pen when you work your with model states
Sorry, the rule in French but can be easy translated if you need to
I am open if you think something could improve the rule
Regards
Replies (0)
