Command to export dwg to pdf
johan.degreef
Advisor Advisor
johan.degreef
Is there a simple few lines iLogic code, I can put in an after save trigger event, to save a dwg as a PDF ((with the same name and same folder as the originating dwg) as soon as I save the dwg?
Many Thanks, Johan
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
CattabianiI
Look at this post: https://forums.autodesk.com/t5/inventor-forum/ilogic-export-to-pdf-options/td-p/7108876
or this example in the help: https://help.autodesk.com/view/INVNTOR/2021/ENU/?guid=GUID-CD4C38D2-FD05-4A2F-9FA7-C5EC5F845753
You can get the wanted destination path with something like that:
Dim destFullFileName As String = IO.Path.ChangeExtension(oDocument.FullFileName, ".pdf")
oDataMedium.FileName = destFullFileName
johan.degreef
Ok thanks, but merging these codes doesn't work.
Need a:
Sub Main()
Sub End
but adding that @Anonymous & end doesn't resolve error.
Public Sub PublishPDF()
    ' Get the PDF translator Add-In.
    Dim PDFAddIn As TranslatorAddIn
    Set PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
    'Set a reference to the active document (the document to be published).
    Dim oDocument As Document
    Set oDocument = ThisApplication.ActiveDocument
    Dim oContext As TranslationContext
    Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = kFileBrowseIOMechanism
    ' Create a NameValueMap object
    Dim oOptions As NameValueMap
    Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    ' Create a DataMedium object
    Dim oDataMedium As DataMedium
    Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
    ' Check whether the translator has 'SaveCopyAs' options
    If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
        ' Options for drawings...
        oOptions.Value("All_Color_AS_Black") = 0
        'oOptions.Value("Remove_Line_Weights") = 0
        'oOptions.Value("Vector_Resolution") = 400
        'oOptions.Value("Sheet_Range") = kPrintAllSheets
        'oOptions.Value("Custom_Begin_Sheet") = 2
        'oOptions.Value("Custom_End_Sheet") = 4
    'Set the destination file name
    'oDataMedium.FileName = "c:\temp\test.pdf"
    'Publish document.
    Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End Sub
A.Acheson
@johan.degreef
This looks like the sample from the API help which is VBA. If your adding the sub main I assume your are converting to vb.net and running it as an iLogic rule, so you need to convert the code. Removing the “Set” is the first step. Assuming there are no other differences.
Regards
Alan
CattabianiI
This should work:
Sub Main()
    'Publish document.
End Sub
johan.degreef
@CattabianiI Many Thanks!
