COMException was unhandled when calling PDFAddin.SaveCopyAs
Hi
This is probably a beginner error, but I can't get past this issue. I found this bit of code in one of the Autodesk blogs and tried to make it work in my application. I want to create a PDF from a given file on the local disk.
   Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
        Dim fileFullName As String = "C:\PublishFolder\2000034_2.ipt"
        ' Create a new instance of Inventor
        Dim _invApp As Inventor.Application
        Dim invAppType As Type = GetTypeFromProgID("Inventor.Application")
        _invApp = CreateInstance(invAppType)
        _invApp.Visible = False
        _invApp.SilentOperation = True
        ' Open a document
        Dim oDoc As Inventor.Document
        oDoc = _invApp.Documents.Open(fileFullName, True)
        ' Get the PDF translator Add-In
        Dim PDFAddIn As TranslatorAddIn
        PDFAddIn = _invApp.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
        'Set a reference to the active document (the document to be published)
        Dim oDocument As Document
        oDocument = _invApp.ActiveDocument
        Dim oContext As TranslationContext
        oContext = _invApp.TransientObjects.CreateTranslationContext
        oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
        ' Create a NameValueMap object
        Dim oOptions As NameValueMap
        oOptions = _invApp.TransientObjects.CreateNameValueMap
        ' Create a DataMedium object
        Dim oDataMedium As DataMedium
        oDataMedium = _invApp.TransientObjects.CreateDataMedium
        ' Check whether the translator has 'SaveCopyAs' options
        If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
            ' Options for drawings...
            oOptions.Value("All_Color_AS_Black") = 0
            'oOptions.Value("Remove_Line_Weights") = 0
            'oOptions.Value("Vector_Resolution") = 400
            'oOptions.Value("Sheet_Range") = kPrintAllSheets
            'oOptions.Value("Custom_Begin_Sheet") = 2
            'oOptions.Value("Custom_End_Sheet") = 4
        'Set the destination file name
        oDataMedium.FileName = fileFullName & ".pdf"
        'Publish document.
        Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
    End Sub
 When the code tries to execute "Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)" it throws an "COMException was unhandled" error.
As I understand the apprenticeserver  dont have the functionallity to create PDF's thats why I try to do it with a hidden Inventor instance (I also want to create other formats, but PDF is the first priority)
Any help or pointers to documentation that can explain this error to me would be greatly appreciated. Thanks
Regards
Bredo
xiaodong_liang
Autodesk Support
Autodesk Support
I used the same code within a standalone EXE program. It works well. Did you hit the problem with a specific drawing or workflow?
Hi
Thanks for the feedback.
Must have been something wrong with the build, the next time I ran the code it worked without any changes 🙂
