Combining Rules
Combining Rules
KWarrenCA
Message 1 of 8
Combining Rules
KWarrenCA
I'm working on some iLogic to copy a view from one drawing to a new drawing then place a parts list from that view. Once the parts list is place to copy it back to the source drawing. Currently I have 3 different iLogic codes.
  1. One code that can copy the view to a new sheet from a template.
  2. One code that can place a parts list that is then sorted.
  3. One code that can copy the parts list to another drawing.
So I'm looking for some help on how to combine these. I would like to have the last code call back the source drawing to copy the parts list to but I'm having some difficulty figuring that out. I'm not sure if I need to do subs or move this to VBA. Any help would be appreciated.
''Copy View to new drawing
Dim oSrcDwg As DrawingDocument
oSrcDwg = ThisApplication.ActiveDocument
oBaseSheet = oSrcDwg.Sheets(1)
Dim oDestDwg As DrawingDocument
''File Location to be Decided
oDestDwg = ThisApplication.Documents.Open("C:\CA Workspace\CAD Standards\Templates\English\BOM DRAWING.idw")
Dim oView As DrawingView
'Check to see if drawing is on the cover page.
Try
	oView = oBaseSheet.DrawingViews(1)
Catch
	MessageBox.Show("There is no view on the cover page", "Place a view", MessageBoxButtons.OK, MessageBoxIcon.Error)
	Return
End Try
If oSrcDwg.ActiveSheet.DrawingViews.Count < 1 Then
	MsgBox("No views found in the source drawing!")
	Return
oModelDoc = oBaseSheet.DrawingViews(1)
Dim oSheet As Sheet
For Each oSheet In oDestDwg.Sheets
	oSheet.Activate
	Call oView.CopyTo(oSheet)
	Exit For
Next
'Used to save destination file
'Call oDestDwg.Save
'Used to close destination file
'Call oDestDwg.Close(True)
''Places Parts in drawing from view placed
Dim oDestDwg As DrawingDocument = ThisApplication.ActiveDocument
oSheet = oDestDwg.Sheets(1)
Dim oBOM As BOM
Dim oPartsLists As PartsLists
Dim oPartsList As PartsList
'Try to get the first view on the sheet
Try
	oView = oSheet.DrawingViews(1)
Catch
	MessageBox.Show("There is no view on the cover page","Place a view", MessageBoxButtons.OK, MessageBoxIcon.Error)
	Return
End Try
'get the model that the view is looking at
oModelDoc =ThisDrawing.Sheet(“COVER:1”).View(oView.Name).ModelDocument
'get the BOM database
oBOM = oModelDoc.ComponentDefinition.BOM
' Make sure  the BOM view is enabled
oBOM.PartsOnlyViewEnabled = True
'get the PartsLists collection
oPartsLists = oSheet.PartsLists
'clean up existing parts lists
For Each oPartsList In oPartsLists
	oPartsList.Delete
Next
'Setting BOM position
Dim BomPlacementPoint As Point2d
Dim oBorder As Border = oSheet.Border
''Location of bom on border
BomPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d (oBorder.RangeBox.MaxPoint.X-20, oBorder.RangeBox.MaxPoint.Y-.95)
'Create new partsList
oPartsList = oPartsLists.Add(oView, BomPlacementPoint, PartsListLevelEnum.kPartsOnly)
'Changes parts list to new style.
oPartsList.Style = oDestDwg.StylesManager.PartsListStyles.Item("BOM (Purchasing)")
''Sort Parts List
Dim oPartsList1 As PartsList
oPartsList1 = oDestDwg.ActiveSheet.PartsLists.Item(1)
oPartsList1.Sort2("VENDOR",1,"STOCK NUMBER",1,"SIZE",1,AutoSortOnUpdate,True)
oPartsList1.Renumber
oPartsList1.SaveItemOverridesToBOM
'PartsList copy to destination folder
'Checks to see if there is a parts list.
Try
	oPartsList = oBaseSheet.PartsLists.Item(1)
Catch
	MessageBox.Show("There is no parts list on the cover page", "Place a parts list", MessageBoxButtons.OK, MessageBoxIcon.Error)
	Return
End Try
oModelDoc = oBaseSheet.PartsLists.Item(1)
'Moves parts list to oDestDwg
Dim oSheet As Sheet
    oSheet.Activate
    Call oPartsList.CopyTo(oSheet)
    Exit For
Next
Replies (7)
Message 2 of 8
A.Acheson
The first question would be do you want to keep this all as separate rules or to create one rule with individual subs? Just looking at what you have it is only a matter of passing each drawing document in as a variable and launch the next sub routine at the end of each or combine them where possible the operations happening on the same document.
Regards
Alan
Message 3 of 8
KWarrenCA
I would like to have them in the same rule. Each rule would have to run once the rule before it finishes.
Message 4 of 8
Cadkunde.nl
I think you want something like this:
Class iRule
	Public test As String = "This variable works in every sub"
	Sub Main()
		Rule1()
		Rule2()
		Rule3()
	End Sub
	Sub Rule1()
		'Copy paste content of your first rule here
	End Sub
	Sub Rule2()
		'Copy paste content of your second rule here
	End Sub
	Sub Rule3()
		'Copy paste content of your third rule here
	End Sub
End Class
Message 5 of 8
tyler.warner
This AU Course can help understand some of the differences between functions, subs, classes. See Tips #4-6. There is a video to go along with the documentation.
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
Message 6 of 8
KWarrenCA
Thank you @Cadkunde.nl and @tyler.warner this is getting me in the right directions. Right now I just trying to get the first 2 rules to work together and keep getting an error on line 65 that no view with the name "View9" was found but there is a view shown on the new sheet. I feel like I'm missing something.
Class iRule
	'Public test As String = "This variable works in every sub"
	Public oSrcDWG As DrawingDocument
	Public oDestDwg As DrawingDocument
	Public oView As DrawingView
	Public oSheet As Sheet
	Sub Main()
		oSrcDWG = ThisApplication.ActiveDocument
		Rule1()
		Rule2()
		'Rule3()
	End Sub
	Sub Rule1()
		oBaseSheet = oSrcDWG.Sheets(1)
		Try
		Catch
			Return
		End Try
			Return
		'Dim oSheet As Sheet
			oSheet.Activate
			Exit For
		Next
	End Sub
	Sub Rule2()
		'Dim oDestDwg As DrawingDocument = ThisApplication.ActiveDocument
		Dim oBOM As BOM
		'Dim oView As DrawingView
		Try
		Catch
			Return
		End Try
		oModelDoc = ThisDrawing.Sheet(“COVER:1”).View(oView.Name).ModelDocument
			oPartsList.Delete
		Next
		BomPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(oBorder.RangeBox.MaxPoint.X - 20, oBorder.RangeBox.MaxPoint.Y - .95)
		''Sort Parts List
		oPartsList1.Sort2("VENDOR", 1, "STOCK NUMBER", 1, "SIZE", 1, AutoSortOnUpdate, True)
	End Sub
	'	Sub Rule3()
	'		'PartsList copy to destination folder
	'		Dim oSrcDwg As DrawingDocument
	'		oSrcDwg = ThisApplication.ActiveDocument
	'		oBaseSheet = oSrcDwg.Sheets(1)
	'		Dim oDestDwg As DrawingDocument
	'		oDestDwg = ThisApplication.Documents.Open("C:\CA Workspace\CAD Standards\Templates\English\BOM DRAWING.idw")
	'		Dim oPartsList As PartsList
	'		'Checks to see if there is a parts list.
	'		Try
	'			oPartsList = oBaseSheet.PartsLists.Item(1)
	'		Catch
	'			MessageBox.Show("There is no parts list on the cover page", "Place a parts list", MessageBoxButtons.OK, MessageBoxIcon.Error)
	'			Return
	'		End Try
	'		oModelDoc = oBaseSheet.PartsLists.Item(1)
	'		'Moves parts list to oDestDwg
	'		Dim oSheet As Sheet
	'		For Each oSheet In oDestDwg.Sheets
	'			oSheet.Activate
	'			Call oPartsList.CopyTo(oSheet)
	'			Exit For
	'		Next
	'	End Sub
End Class
Message 7 of 8
A.Acheson
You will need to  remove the reference to ilogic model Document. If you look at object reference of this it will be for the the document you originally launched the rule from and not the document your currently in which should be the temporary drawing.  Use the API method instead. You may have to "activate" the drawing document/ sheet as well.
Dim assyDocName As String =  oView.ReferencedDocumentDescriptor.FullDocumentName
'open assembly doc invisibly
Dim oModelDoc As AssemblyDocument = ThisApplication.Documents.Open(assyDocName, False
Regards
Alan
Message 8 of 8
KWarrenCA
@A.Acheson That did the trick. It is now working correctly just need to add a few checks so no one runs it if there already is a parts only parts list. Thank you for the help!
