Combine steps in one feature
Mustafa.Salaheldin
Mustafa.Salaheldin
Hello
I am new to Inventor, and I want to combine multiple features in one node in the model browser.
I have created a clientfeature called DuPod Feature1, and I want all the following steps (from Work Point 2 until Split 1) to be merged under this node.
I am using Inventor 2026 and C# .Net 8.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Michael.Navara
Hi @Mustafa.Salaheldin
Here is the small example how to create ClientFeature.
Usually it is used for features created by API, not for manually created features.
void Main()
    var part = ThisApplication.ActiveDocument as PartDocument;
    var compDef = part.ComponentDefinition;
    //Assumes there are at least two surface bodies in the part
    var body1 = compDef.SurfaceBodies[1];
    var body2 = compDef.SurfaceBodies[2];
    //Crate model features which should be combined in ClientFeature
    var workPoint1 = compDef.WorkPoints.AddFixed(
        ThisApplication.TransientGeometry.CreatePoint(0, 0, 0)
    var workPoint2 = compDef.WorkPoints.AddFixed(
        ThisApplication.TransientGeometry.CreatePoint(0, 0, 0.5)
    var workAxis1 = compDef.WorkAxes.AddByTwoPoints(workPoint1, workPoint2);
    //Keep input work points at the root of the model tree.
    workAxis1.ConsumeInputs = false;
    var workPlane1 = compDef.WorkPlanes.AddByLineAndPoint(workAxis1, workPoint2);
    var toolBodies = ThisApplication.TransientObjects.CreateObjectCollection();
    toolBodies.Add(body2);
    var combineFeature1 = compDef.Features.CombineFeatures.Add(body1, toolBodies, PartFeatureOperationEnum.kJoinOperation);
    var body3 = combineFeature1.SurfaceBody;
    var splitFeature1 = compDef.Features.SplitFeatures.SplitBody(workPlane1, body3);
    //Create ClientFeature
    var clientFeatureDefinition = compDef.Features.ClientFeatures.CreateDefinition(
        "SampleFeature",
        workPoint1,
        splitFeature1,
        null
    compDef.Features.ClientFeatures.Add(clientFeatureDefinition, "YOUR-ADDIN-CLSID-GUID-HERE");
mustafa_bakrE8NT7
Thanks @Michael.Navara
