combine ilogic rules
Bram_Jessen
Bram_Jessen
Hello all,
I've tried to find a solution for my challenge on this forum but haven't seem to crack it.
I even asked chatGTP for help but he is not of much use when it comes to correct ilogic code.
The goal is to launch this code from a part (or assembly), open the drawing (close the part/assy), then make a PDF from the drawing, then close the drawing.
I've tried it as external ilogic rule, and combining the code, but it gets me stuck.
Currently it says i have an error on line 81.
Can someone help me on my way?
Thanks in advance
Sub Main()
    ' Call Main1 subroutine
    Call Main1
    ' Call Main2 subroutine
    Call Main2
    ' Call Main3 subroutine
    Call Main3
End Sub
' Define Main1 subroutine
Sub Main1()
Dim teknummer As String
Dim oDocumentMain1 As Document
oDocumentMain1 = ThisApplication.ActiveDocument
If iProperties.Value("Project", "Stock Number") = ""
	teknummer = iProperties.Value("Project", "Part Number")
Else
	teknummer = iProperties.Value("Project", "Stock Number")
Try
	ThisDoc.Launch(ThisDoc.Path & "\" & teknummer & ".idw")
Catch
	If teknummer = "" Then
	MessageBox.Show("Beetje lastig om een tekening zonder nummer te openen", "ERROR")
	Else
	MessageBox.Show(ThisDoc.Path & "\" & teknummer & ".idw niet gevonden")
	End if
End Try
ThisDoc.Document.Close(True) 'True means don't save it when closing
End Sub
' Define Main2 subroutine
Sub Main2()
'Define the open document
Dim openDocMain2 As Document
openDocMain2 = ThisDoc.Document
'Look at the model file referenced in the open document
Dim docFileMain2 As Document
docFileMain2 = ThisDoc.ModelDocument
'format model file name
Dim FNamePosMain2 As Long
FNamePosMain2 = InStrRev(docFileMain2.FullFileName, "\", -1)
Dim docFNameMain2 As String
docFNameMain2 = Right(docFileMain2.FullFileName, Len(docFileMain2.FullFileName) -FNamePosMain2)
'define the property set
customPropertySet = docFileMain2.PropertySets.Item("Inventor User Defined Properties")
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oRevNum = iProperties.Value("project", "revision number")
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocumentMain2 = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMediuma = ThisApplication.TransientObjects.CreateDataMedium
oDataMediumb = ThisApplication.TransientObjects.CreateDataMedium
If oPDFAddIn.HasSaveCopyAsOptions(oDocumentMain2, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Remove_Line_Weights") = 0
oOptions.Value("Vector_Resolution") = 600
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2'oOptions.Value("Custom_End_Sheet") = 4
'get PDF target folder path
oFolder = "Z:\Cad\Documenten\Werkmap Kevin\Inventor Project\Workspace\Export\"
Dim Bestandsnaam As String
'If Left(Right(iProperties.Value(docFNameMain2, "Project", "Part Number"), 3), 1) = "D" Or Left(Right(iProperties.Value(docFNameMain2, "Project", "Part Number"), 3), 1) = "S"
'Bestandsnaam = iProperties.Value(docFNameMain2,"Project", "Part Number")
'Else
Bestandsnaam = iProperties.Value(docFNameMain2, "Project", "Stock Number")
'End If
Dim revisienummer As String
revisienummer = iProperties.Value(docFNameMain2, "Project", "Revision Number")
Dim jaar As String
Dim maand As String
Dim dag As String
Dim uur As String
Dim minuut As String
Dim datum As String
jaar = Date.Now.Year.ToString
If Len(Date.Now.Month.ToString) = 1
maand = "0" & Date.Now.Month.ToString
Else
maand = Date.Now.Month.ToString
If Len(Date.Now.Day.ToString) = 1
dag = "0" & Date.Now.Day.ToString
Else
dag = Date.Now.Day.ToString
If Len(Date.Now.Hour.ToString) = 1
uur = "0" & Date.Now.Hour.ToString
Else
uur = Date.Now.Hour.ToString
If Len(Date.Now.Minute.ToString) = 1
minuut = "0" & Date.Now.Minute.ToString
Else
minuut = Date.Now.Minute.ToString
datum = jaar &" "& maand & dag &" "& uur & minuut
 'Set the PDF target file name
oDataMediumb.FileName = oFolder & "\RevisieBeheer\" & Bestandsnaam & "-" & revisienummer & " (" & datum & ").pdf"
oDataMediuma.FileName = oFolder & "\PDF\" &Bestandsnaam & ".pdf"
'Set timestamp
iProperties.Value("Custom", "TIMESTAMP") = revisienummer &" - "& datum
Try
'Publish document
	Select Case Right(revisienummer, 1)
	Case ""
		oPDFAddIn.SaveCopyAs(oDocumentMain2, oContext, oOptions, oDataMediumb)
	Case "-"
	Case "+"
	Case Else
	End Select
	oPDFAddIn.SaveCopyAs(oDocumentMain2, oContext, oOptions, oDataMediuma)
'MessageBox.Show("PDF file vrijgegeven:" & vbLf & oFolder & "PDF\" & Bestandsnaam & ".pdf")
	Catch
	MessageBox.Show("Kan pdf niet opslaan, mogelijk is bestand in gebruik"& vbLf &"Sluit de pdf af en/of selecteer een ander bestand in de windows verkenner")
	End Try
End Sub
' Define Main3 subroutine
Sub Main3()
End Sub
jwingateRJECD
You were on the right path with external rules, but you need to separate the actions into different rules, and call them from within a main rule, at least that is what I have gotten to work for me. Something like this:
ThisDoc.Launch(ThisDoc.Path & "\" & iProperties.Value("Project", "Part Number") & ".idw")
oDrawDoc = ThisApplication.ActiveDocument
iLogicVb.Automation.RunExternalRule(oDrawDoc, "*Put the file location of your external pdf rule here*")
Here is the rule that I use for exporting PDF's:
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oOptions.Value("Vector_Resolution") = 1200
oFolder = oPath
ThisApplication.ActiveView.Update()
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
oDataMedium.FileName = oFolder & "\" & oFileName & ".pdf"
oPDFAddIn.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oDataMedium)'For PDF's
 Hope this helps.
Bram_Jessen
Thank you for steering me in the right direction, your addition did the trick.
