Color pattern iLogic
e_jansonLT2PV
Message 1 of 23
e_jansonLT2PV
I have an asset of one solid body. There are patterns which consist of several extrusions. I want to color that extrusions differently, but I can only give the whole pattern one color if I use the Feature Properties.
Is there a way to color different features of a pattern in different colors using ILogic?
Replies (22)
Message 21 of 23
Frederick_Law
It can be done in part but assembly will be a lot easier and easier to modify.
One wrong step in part, colour will be wrong.
Message 22 of 23
_dscholtes_
@e_jansonLT2PV
Thank you for answering my questions, although I think I have a solution that doesn't require them and you can keep patterning features.
So the code below requires the names of the extrusions you want to color (line 3-4) and the appearance names used to color them (line 8-9). It will then copy the matching library appearances to the document so they can be used (line 29-48), it will color the listed extrusions (line 52-65) as they are not 'part' of any pattern and the last section (line 69-114) will go through all pattern elements and all the faces each of them contains and check if the feature that created each face was an extrude feature listed at the beginning. If so, it colors them.
iLogic rule:
    'Set list of features to color
    Dim sFeatureName As New ArrayList
    sFeatureName.Add ("Box1")
    sFeatureName.Add ("Pallet1")
    'Set list of appearances to use
    Dim sFeatureColorName As New ArrayList
    sFeatureColorName.Add ("Yellow")
    sFeatureColorName.Add ("Orange")
    'Check if sufficient colors are defined
    If sFeatureColorName.Count < sFeatureName.Count Then
		MessageBox.Show("Not enough appearances in the list, aborting...","iLogic: Rule Name",MessageBoxButtons.OK)
        Exit Sub
    'Set various references
    Dim oDoc As PartDocument = ThisApplication.ActiveEditDocument
    Dim oCompDef As PartComponentDefinition = oDoc.ComponentDefinition
	Dim oPartFeats As PartFeatures = oCompDef.Features
	'Create transaction
	Dim oTrans As Transaction = ThisApplication.TransactionManager.StartTransaction(oDoc, "iLogic: Rule Name")
	    'Declarations
	    Dim oLibAsset As Asset
	    Dim oLocAsset(sFeatureColorName.Count-1) As Asset
	    Dim i As Integer
		'Iterate through all listed appearances
	    For i = 0 To sFeatureColorName.Count-1
			Try
				'Try to access the appearances asset from the document appearances library
				oLocAsset(i) = oDoc.AppearanceAssets(sFeatureColorName(i))
	        Catch
		        'Get listed appearance from library
		        oLibAsset = ThisApplication.AssetLibraries.Item("Inventor Material Library").AppearanceAssets(sFeatureColorName(i))
	            'Copy the asset to the document appearances library
	            oLocAsset(i) = oLibAsset.CopyTo(oDoc)
			End Try
	    Next i
	    'Declarations
		Dim oExtFeat As Inventor.ExtrudeFeature
		'Iterate through all extrusion features
		For Each oExtFeat In oCompDef.Features.ExtrudeFeatures
		    'Check if extrusion is in the feature list and color it if so.
		    For i = 0 To sFeatureName.Count-1
		        If oExtFeat.Name = sFeatureName(i) Then
					oExtFeat.Appearance = oLocAsset(i)
					Exit For
		    Next i
		Next
	    'Declarations
	    Dim oRecPatFeat As RectangularPatternFeature
	    Dim oPatElem As FeaturePatternElement
	    Dim oFace As Face
	    Dim oObject As Object
	    Dim bListed As Boolean
	    'Iterate through all rectangular patterns
	    For Each oRecPatFeat In oPartFeats.RectangularPatternFeatures
	        'Iterate through all pattern elements
	        For Each oPatElem In oRecPatFeat.PatternElements
	            'Check if element contains faces
	            If oPatElem.Faces.Count > 0 Then
	                'Iterate through all faces in the element
	                For Each oFace In oPatElem.Faces
	                    'Iterate through all source features of the face
	                    For Each oObject In oFace.[_CreatedByFeatures]
	                        'Check if source feature is an extrusion
	                        If oObject.Type = kExtrudeFeatureObject Then
	                                If oObject.name = sFeatureName(i) Then
	                                    bListed = True
	                                    Exit For
	                            Next i
	                            'Color face when extrusion was listed and stop iterating source features
	                            If bListed = True Then
	                                oFace.Appearance = oLocAsset(i)
	                                bListed = False
	                                Exit For
	                    Next
	                Next
	        Next
	    Next
	'End transaction
	oTrans.End
Message 23 of 23
e_jansonLT2PV
Thanks a lot!
