Color change of list of faces in Assembly file .iam
anil_dangi
Message 1 of 1
anil_dangi
Hello everyone,
I am trying to assign a permanent color to selected faces (not the entire body) in an Assembly file using the FinishFeature API.
So far, I tried SetRenderStyle, but it either applied to the entire part or threw an error (E_NOTIMPL). However, I found that FinishDefinition API can help apply color only to selected faces.
There is already a tool under Inventor UI :
 Assemble Tab → Appearance Panel → "Finish" Tool
When clicked, it applies a color/material kind of thing to the selected faces in the assembly.
1. How can I correctly implement this in C# using FinishFeature API or above feature?
2.  Is there a better way to handle face-level appearance inside an Assembly document?
Below is my working code for this:
public void AssignColorToSelectedFaces(List<Face> selectedFaces)
    try
        // Get the active document (should be an Assembly)
        AssemblyDocument asmDoc = StandardAddInServer.InventorApp.ActiveDocument as AssemblyDocument;
        if (asmDoc == null)
            MessageBox.Show("Please open an assembly document in Inventor.", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error);
            return;
        // Iterate through selected faces
        foreach (Face face in selectedFaces)
            // Get the ComponentOccurrence that owns the face
            ComponentOccurrence occurrence = face.Parent as ComponentOccurrence;
            if (occurrence == null) continue;
            // Get the PartDocument inside the occurrence
            PartDocument partDoc = occurrence.Definition.Document as PartDocument;
            if (partDoc == null) continue;
            PartComponentDefinition partDef = partDoc.ComponentDefinition;
            // Ensure there is a FinishFeature object
            if (partDef.Features.FinishFeatures.Count == 0)
                partDef.Features.FinishFeatures.Add();
            // Get the FinishFeature object
            FinishFeature finishFeature = partDef.Features.FinishFeatures[1];
            // Assign a color (Get an existing AppearanceAsset or create one)
            string appearanceName = "CustomFaceColor";
            AppearanceAsset appearanceAsset;
            try
                appearanceAsset = partDoc.AppearanceAssets[appearanceName];
            catch
                // Create new Appearance Asset if not found
                appearanceAsset = partDoc.AppearanceAssets.Add(appearanceName);
                appearanceAsset.DiffuseColor = Inventor.Color.Create(255, 0, 0); // Red
            // Apply appearance to the face
            finishFeature.AddFace(face, appearanceAsset);
        // Update the document
        asmDoc.Update();
    catch (Exception ex)
        MessageBox.Show($"Error assigning color to faces: {ex.Message}", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error);
Replies (0)
