Coincident constraint - why so complicated?
llorden4
llorden4
I constantly struggle with the Coincident constraint, and it seems a bit unnecessary the additional steps that are required to make this constraint work within iLogic.
I don't have to take these additional steps with the other constraints so maybe this is just a handling bug within Inventor, but when I want to use this Coincident constraint with sketchpoints, I must first assign the sketchpoint to a variable name, I can't simply point to the sketchpoint itself.
Example that fails but typically works with other constraint types:
oSketch.GeometricConstraints.AddCoincident(Line1.EndSketchPoint, Arc1.CenterSketchPoint)
Example that succeeds:
oSKP1 = Line1.EndSketchPoint
oSKP2 = Arc1.CenterSketchPoint
oSketch.GeometricConstraints.AddCoincident(oSKP1, oSKP2)
 It's a bit frustrating to have to keep re-figuring these steps out whenever I come back to needing this constraint and seems an unnecessary fluff factor to coding.  The editor's pop-up shows these variable types as "SketchPoints" while I'm typing, so the format appears correct and I fail to understand why the direct pointer fails to work in this case.
Something I'm overlooking or another process that's consistent in approach with all the other constraints?
Currently using Inventor 2022.2
Autodesk Inventor Certified Professional
JelteDeJong
I tried the following code and it works for me.
Dim doc As PartDocument = ThisDoc.Document
Dim oSketch As PlanarSketch = doc.ComponentDefinition.Sketches.Item(1)
Dim Arc1 As SketchArc = oSketch.SketchArcs.Item(1)
Dim Line1 As SketchLine = oSketch.SketchLines.Item(1)
I can't reproduce the problem. Can you post the complete script you are working on?
Jelte de Jong
Blog: hjalte.nl - github.com
llorden4
Here's an executable of the issue you can copy and paste to run...
Sub Main
Dim oDoc As PartDocument = ThisDoc.Document
Dim oCompDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oWorkPlane As WorkPlane
Dim oLine(3) As SketchLine
'for sample
Dim FlatAngle As Double = 30
Dim Dia As Double = 30
Dim Value As Double
Dim IsSlipJoint As Boolean = False
Dim MatThick As Double = 0.25
'close any active sketches
If TypeOf ThisApplication.ActiveEditObject Is Sketch Then
    oSketch = ThisApplication.ActiveEditObject
    oSketch.ExitEdit
'remove any previously created stuff
While oCompDef.Features.Count > 0
	oCompDef.Features.Item(oCompDef.Features.Count).Delete
End While
While oCompDef.Sketches.Count > 0
	oCompDef.Sketches.Item(oCompDef.Sketches.Count).Delete
End While
'make new stuff
oWorkPlane = oCompDef.WorkPlanes.Item("XZ Plane")
oSketch = oCompDef.Sketches.Add(oWorkPlane)
oSketch.Name = "Sealer sketch"
oGC = oSketch.GeometricConstraints
oDC = oSketch.DimensionConstraints
Value = (Dia / 2 * 2.54) * Tan(FlatAngle / 2 * PI / 180)
oLine(1) = oSketch.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(-Value, -(Dia / 2 * 2.54)), oTG.CreatePoint2d(0, 0))
oLine(2) = oSketch.SketchLines.AddByTwoPoints(oLine(1).EndSketchPoint, oTG.CreatePoint2d(Value, -(Dia / 2 * 2.54)))
oGC.AddGround(oLine(1).EndSketchPoint)
oGC.AddHorizontalAlign(oLine(1).StartSketchPoint, oLine(2).EndSketchPoint)
If IsSlipJoint Then												'slipjoint = polygon shape
	oLine(3) = oSketch.SketchLines.AddByTwoPoints(oLine(2).EndSketchPoint, oLine(1).StartSketchPoint)
	oSKP = oSketch.SketchPoints.Add(oTG.CreatePoint2d(0, 0), False)
	oGC.AddMidpoint(oSKP, oLine(3))
	oGC.AddVerticalAlign(oSKP, oLine(1).EndSketchPoint)
	oTmp = oDC.AddTwoLineAngle(oLine(1), oLine(2), oTG.CreatePoint2d(0, oLine(1).Geometry.MidPoint.Y), False)
	oTmp.Parameter.Expression = CStr(FlatAngle) & " deg"
	oTmp = oDC.AddOffset(oLine(3), oLine(1).EndSketchPoint, oTG.CreatePoint2d(0, oLine(1).Geometry.MidPoint.Y), False, False)
	oTmp.Parameter.Expression = CStr(Dia / 2) & " in"
Else
	oArc = oSketch.SketchArcs.AddByCenterStartEndPoint(oLine(1).EndSketchPoint, oLine(2).EndSketchPoint, oLine(1).StartSketchPoint, False)
'This line fails
	oGC.AddCoincident(oLine(1).EndSketchPoint, oArc.CenterSketchPoint)
'These REM'd lines don't fail
'	oSKP1 = oLine(1).EndSketchPoint
'	oSKP2 = oArc.CenterSketchPoint
'	oGC.AddCoincident(oSKP1, oSKP2)
	oTmp = oDC.AddRadius(oArc, oTG.CreatePoint2d(0, -Dia / 4 * 2.54), False)
oProfile = oSketch.Profiles.AddForSolid
oExtrudeDef = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kNewBodyOperation)
oExtrudeDef.SetDistanceExtent(MatThick * 2.54, kNegativeExtentDirection)
oExtrude = oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef)
oExtrude.Name = "Sealer Plate slice"
End Sub
Michael.Navara
If you want to joint two curves by its end points, don't use AddCoincident() method but Merge two points to one.
This code works for me.
'This line fails
'oGC.AddCoincident(oLine(1).EndSketchPoint, oArc.CenterSketchPoint)
oLine(1).EndSketchPoint.Merge(oArc.CenterSketchPoint)
Here is full description of Sketch constraints API. At the bottom of the page is described your issue
https://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-30082FDF-9476-49C6-BB3E-0DE90A3CC812
llorden4
How in the world did you ever find that line of text?  Thanks for that link and solution.
Michael.Navara
Because I was in the same trouble few years ago.😁
