Coincident constrain between sketch block point and grounded point/projected point
taher.basha
taher.basha
I am trying to create Coincident constrain between sketch block insertion point and grounded/projected point
I have tried with the below code:
TransientGeometry tg = invApp.TransientGeometry;
PartDocument pd = invApp.ActiveDocument as PartDocument;
PartComponentDefinition pcd = pd.ComponentDefinition;
PlanarSketch sk = pcd.Sketches["Sketch1"];
SketchBlock sb = sk.SketchBlocks[1];
SketchPoint pt = sb.Definition.InsertionPoint;
SketchEntity cpt = sk.AddByProjectingEntity(pcd.WorkPoints[1]);
sk.GeometricConstraints.AddCoincident((SketchEntity)pt, cpt);
dalton98
Hello. You need to get the sketch point object from the sketch block. Example
You will need to convert this from vb.net
Dim tg As TransientGeometry = ThisApplication.TransientGeometry
Dim pd As PartDocument = ThisApplication.ActiveDocument
Dim pcd As PartComponentDefinition = pd.ComponentDefinition
Dim sk As PlanarSketch = pcd.Sketches.Item("Sketch1")
Dim sb As SketchBlock = sk.SketchBlocks(1)
Dim pt As SketchPoint = sb.Definition.InsertionPoint
Dim cpt As SketchEntity = sk.AddByProjectingEntity(pcd.WorkPoints(1))
Dim pt1 As SketchPoint = sb.GetObject(pt)
sk.GeometricConstraints.AddCoincident(pt1, cpt)
