Code to See if a Drawing Note is Detached?
el_jefe_de_steak
el_jefe_de_steak
Hi, I'm working on some code that "cleans up" a drawing, automatically removing any broken annotations and drawing dimensions.
The process is very simple for dimensions and balloons:
For Each oDim As GeneralDimension In thisSheet.DrawingDimensions.GeneralDimensions
   If oDim.Attached = False Then
      oDim.Delete()
Next
However, I cannot seem to find a property that works like the .Attached property for LeaderNotes and HoleThreadNotes. There is obviously something that does this somewhere in Inventor, because leader notes turn pink, and Hole and Thread notes grey out when they become "detached".
Does anyone know how to do this?
JelteDeJong
For the leader notes, you have to check the nodes on the leader. For the HoleThreadNote I think there is attached property. At least this rule works for me.
Dim doc As DrawingDocument = ThisDoc.Document
Dim sheet As Sheet = doc.ActiveSheet
For Each note As LeaderNote In sheet.DrawingNotes.LeaderNotes
    ' Dim t = note.Leader.AllNodes.Count
    If (note.Leader.HasRootNode = False) Then
        ' This happens if the leader has been deleted.
    Else
        Dim attachedNodeList = note.Leader.AllNodes.
            Cast(Of LeaderNode).Where(Function(n) n.AttachedEntity IsNot Nothing).ToList()
        If (attachedNodeList.Count = 0) Then
            note.Delete()
Next
For Each note As HoleThreadNote In sheet.DrawingNotes.HoleThreadNotes
    If (note.Attached = False) Then
        note.Delete()
Next
Jelte de Jong
Blog: hjalte.nl - github.com
Ralf_Krieg
Hello
I think it would be easier to set
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
oDrawDoc.DrawingSettings.PreserveOrphanedAnnotations = False
EDIT: If the HoleThreadNote on a threaded hole is attached to the hole (not to the thread symbol) and the hole is deleted, the HoleThreadNote is not not getting pink. Instead it's getting light gray. If this is selected manual, the API returns the ActiveSheet as selected object and in this case there's no attached property and  it's not possible to delete.
R. Krieg
RKW Solutions
www.rkw-solutions.com
el_jefe_de_steak
Thanks, to both @Ralf_Krieg and @JelteDeJong. I found that both of your solutions worked to some extent.
@Ralf_Krieg this works amazingly, and I have implemented it into my project. One thing to note is that it does not delete broken dimensions, only annotation objects.
@JelteDeJong you were absolutely correct about the HoleThreadNote having an "Attached" property. I simply overlooked this in the API reference. However, I could not get your code to work for the LeaderNote. I get this error:
  • System.MissingMemberException: 'Public member 'Cast' on type 'LeaderNodesEnumerator' not found.'
For context, I am using this in VB.net with a program compiled in Visual Studio. I have not tried it in iLogic, but I assume that I would get the same result.
