CODE TO ATTACH BALLOONS FROM LIST WITH MATCHING PROPERTY
eric.smyth
eric.smyth
I am trying to piece together, with my limited iLogic abilities, to have a code that will allow you to select a balloon and then automatically attach balloons from list that have the matching custom ipropery value. When I have multiple parts in a view that cover each other I would select to add from list and do so. the parts list is quite long so this manually takes a long time. Would anyone have something like this?
Curtis_Waguespack
Hi @eric.smyth ,
See this example to get you started.
Hope this helps,
Curtis
Dim oBalloon As Inventor.Balloon = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingBalloonFilter, "Select a balloon.")
If oBalloon Is Nothing Then Exit Sub
Dim oRow As DrawingBOMRow
Dim oTargetDoc As Inventor.Document
Dim oRowDoc As Inventor.Document
Dim oDBOM As DrawingBOM = oBalloon.BalloonValueSets.Item(1).ReferencedRow.Parent
For Each oRow In oDBOM.DrawingBOMRows
	If oRow.BOMRow.ItemNumber = oBalloon.BalloonValueSets.Item(1).Value Then
		oTargetDoc = oRow.BOMRow.ComponentDefinitions.Item(1).Document
Next
If oTargetDoc Is Nothing Then Exit Sub
Dim CustomPropSet As PropertySet
oTargetDocCustomPropSet = oTargetDoc.PropertySets.Item("Inventor User Defined Properties")
oTargetDocPropValue = oTargetDocCustomPropSet.Item("CustomProp1").Value
i = 0
	oRowDoc = oRow.BOMRow.ComponentDefinitions.Item(1).Document
	If oRow.BOMRow.ItemNumber = oBalloon.BalloonValueSets.Item(1).Value Then Continue For
	CustomPropSet = oRowDoc.PropertySets.Item("Inventor User Defined Properties")
	oDocPropValue = CustomPropSet.Item("CustomProp1").Value
	If oDocPropValue = oTargetDocPropValue Then
		Dim oBalloonValueSet As BalloonValueSet = oBalloon.BalloonValueSets.Add(oRow)
		i = 1+1
Next
If i = 0 Then MsgBox("No other balloons items found with target iProperty value",,"iLogic")
eric_smythC4KJK
Seems to be an issue with line 10.
(Object reference not set to an instance of an object.)
	If oRow.BOMRow.ItemNumber = oBalloon.BalloonValueSets.Item(1).Value Then '(Object reference not set to an instance of an object.)
Next
i = 0
		i = 1+1
Next
eric_smythC4KJK
Does having these columns in the bom change how the code finds the values.
I am assuming that "CustomProp1" would change to my "DEG" custom property.
eric_smythC4KJK
I added these checks before the error
    If oRow.BOMRow Is Nothing Then
        MsgBox("oRow.BOMRow is Nothing")
        Continue For
    If oBalloon.BalloonValueSets.Count = 0 Then
        MsgBox("No BalloonValueSets found")
        Continue For
    If oBalloon.BalloonValueSets.Item(1) Is Nothing Then
        MsgBox("oBalloon.BalloonValueSets.Item(1) is Nothing")
        Continue For
Next
 So apparently the oRow.BOMRow is Nothing and is exiting the sub. I'm trying to understand what this line is exactly looking for.
is item(1),value the first level of that row? would item(2) be the next level if it were and sub assembly?
I also have a custom property ("tag") in the balloon itself. would that change the line of code above as well?
eric_smythC4KJK
item(1) is the first item in the balloon set, item(2) is the second and so on. if so, would a value with letters and numbers come back as nothing?
