Code for SCULPT in multibody part
Hi everybody,
Please take a look at the attached part. It is a multibody created by pattern with "Create New Solid" option. The objective is, trimming all elements (Solid Bodies) by the same surface at once...This time, I am trying to involve SCULPT method. The rule runs and generates SCULPT for one Solid Body only.
Does anybody have any idea if it could be possible in general? Please suggest.
Thank you.
ekinsb
Both the Split and Sculpt commands are limited to operating on a single body.  You can see this interactively.  If there's only one body in the part then the command goes ahead.  If there are multiple bodies, then you have to select the one body you want to operate on.  You'll need to perform multiple split or sculpt operations, one for each body, to get the result you want.
Brian Ekins
Mod the Machine blog
