Code for retrieve model Annotations in drawing
richie_rQYQ8U
Message 1 of 8
richie_rQYQ8U
Hi All,
Is there a code for retrieving model annotations in the drawing ?
Thank you
Replies (7)
Message 2 of 8
BM_Ashraf
This is the Syntax
GeneralDimensions.Retrieve Method
Parent Object: GeneralDimensions
Description
Method that retrieves sketch and/or model dimensions into the drawing.
Syntax
GeneralDimensions.Retrieve( ViewOrSketch As Object, [DimensionsToRetrieve] As Variant ) As GeneralDimensionsEnumerator
So, You need a Drawing sheet and Drawing view
Ex.
Dim oDrawView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Please select a View, Esc to Cancel ")
If oDrawView Is Nothing Then Exit Sub
Dim oSheet As Sheet = oDrawView.Parent
oSheet.DrawingDimensions.GeneralDimensions.Retrieve(oDrawView)
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Blue Mech
Add-ins for Inventor!
Message 3 of 8
d_bouvy
It seems impossible to make model annotation of an assembly visible in a drawing with VBA... Is anyone know this ?
The code above put all dimensions of sketches and features, but not model annotations....
Message 4 of 8
WCrihfield
Hi @d_bouvy.  Have you already tried turning this setting on?
DrawingView.Include3DAnnotations
Also, if those 3D model annotations were not directly created within the main/top assembly, then you would need to dig for the 'real' ones within the components, then get a reference to their 'proxy' representations within the main/top assembly, then gather those proxy versions to be included in the drawing.  The 'retrieve' process generally only works for top level stuff in the main model, not for stuff below that level.
Wesley Crihfield
(Not an Autodesk Employee)
Message 5 of 8
richie_rQYQ8U
Hi Thank you for your reply,
No i didn't try that
Can you show me how to do that please?
Message 6 of 8
WCrihfield
Sure.  Below is a link to a similar post I responded to in a similar way about 2 years ago which contains a very basic iLogic example.
https://forums.autodesk.com/t5/inventor-programming-ilogic/retrieve-3d-dimensions-placed-on-an-assem...
But I can post another example here too.  This example will iterate through each sheet, and each view on each sheet, setting that view property to True on each one.  I believe this setting is similar to the one you see on the 'Recovery Options' tab of the Drawing View editing dialog, where there is a checkbox named 'All Model Dimensions'.
Sub Main
	Dim oDDoc As DrawingDocument = TryCast(ThisDoc.Document, Inventor.DrawingDocument)
	If oDDoc Is Nothing Then Logger.Debug(iLogicVb.RuleName & " exited (wrong DocumentType)") : Return
	Dim oSheets As Inventor.Sheets = oDDoc.Sheets
	Dim oASheet As Inventor.Sheet = oDDoc.ActiveSheet 'record originally active sheet
	For Each oSheet As Inventor.Sheet In oSheets
		oSheet.Activate
		Dim oViews As DrawingViews = oSheet.DrawingViews
		If oViews.Count = 0 Then Continue For 'skip to next sheet
		For Each oView As DrawingView In oViews
			'<<< setting that Boolean type property to True here >>>
			oView.Include3DAnnotations = True
		Next 'oView
		oSheet.Update
	Next 'oSheet
	'restore originally active sheet to active again
	If oDDoc.ActiveSheet IsNot oASheet Then
		oASheet.Activate
End Sub
At the following link, I had also responded to another similar forum post about 3 1/2 years ago where I showed a code way to simulate the manual process of retrieving model annotations in a drawing, but I generally do not recommend using a command execution and SendKeys type routine anymore, due to the inherent dangers of using the SendKeys methods (the keystrokes could potentially get sent to the wrong place, which could have an unknown effect).
https://forums.autodesk.com/t5/inventor-programming-ilogic/retrieve-model-annotations-ilogic/m-p/975...
There are also other forum posts out there on this subject too, which may offer more insights, and different code examples.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
Message 7 of 8
richie_rQYQ8U
thank you for your solution @WCrihfield
Good thing is the code is working
but i can use the code one time next time if i try it
it was not working
i need to double click the view to get the annotations.
Message 8 of 8
d_bouvy
Thanks, it works !
I don't know why, but with CommandManager.ControlDefinitions.Item("DrawingRetrieveDimsCmd").Execute, dimensions don't appear when I was printing in PDF.
Now it seems great with drawingview.include3Dannotations
