Co-ordinates of a named workpoint (in component) relative to assembly origin
gcoombridge
Advisor Advisor
gcoombridge
Hi All,
I'm after a way to extract the co-ordinates of one (or many) named work points in a part from within the assembly environment and to compare them to the assembly origin. I.e. I want the co-ordinates relative to the assembly zero. This is for returning the positions of items in a layout.
I've found several posts that provide this from within a part. This code works fine:
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
CoOrd = oDoc.ComponentDefinition.WorkPoints("Test Point")
CoOrd_X = CoOrd.Point.X * 10
CoOrd_Y = CoOrd.Point.Y * 10
CoOrd_Z = CoOrd.Point.Z * 10
CoOrdX= Round(CoOrd_X, 0)
CoOrdY= Round(CoOrd_Y, 0)
CoOrdZ= Round(CoOrd_Z, 0)
I am thinking there will just be something in the syntax to delve into the component level...? I assumed I could add the part names and instance prior the work point name string but this does not work.
As a secondary question why does this code return centimeters? (Hence the *10 multiplier)
Thanks!
Glenn
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
JaneFan
Hey @gcoombridge
Here is the way to navigate to component level of assembly:
SyntaxEditor Code Snippet
Dim oDoc As AssemblyDocument
Dim oOccDef As ComponentDefinition
oOccDef = oDoc.ComponentDefinition.Occurrences.ItemByName("ComponentName").Definition
Dim oWP As WorkPoint
oWP = oOccDef.WorkPoints("Test Point")
 If you are running code in iLogic editor, the simpler way to get component level is using Components object exposed in iLogic that the oOccDef line can be replaced with this:
oOccDef = Components("ComponentName").Occurrence.Definition
Jane Fan
Inventor/Fusion QA Engineer
gcoombridge
Perfect! Thanks Jane
gcoombridge
Hi @JaneFan,
Just looking at this again it is returning the distance from the origin of the part not the assembly. Sorry my post was pretty unclear. As an addition to this can you advise how I would produce the distance from the named point and the assembly origin?
I thought about adding the distance between the assembly origin and part origin to the result above but this would be invalid with a part rotation.
Thanks for your help!
JaneFan
Do you need get the position in assembly coordinate system of the work point in component level? If so, we need get a proxy of the work point in assembly coordinate system:
Dim oOcc As ComponentOccurrence
oOcc = oDoc.ComponentDefinition.Occurrences.ItemByName("Part1:1")
oOccDef = oOcc.Definition
oWP = oOccDef.WorkPoints("Test")
MsgBox("x: " + oWP.Point.X.ToString() + ", y: " + oWP.Point.Y.ToString() + ", z: " + oWP.Point.Z.ToString() )
Dim oWPProxy As WorkPointProxy
Call oOcc.CreateGeometryProxy(oWP, oWPProxy)
MsgBox("x: " + oWPProxy.Point.X.ToString() + ", y: " + oWPProxy.Point.Y.ToString() + ", z: " + oWPProxy.Point.Z.ToString() )
Jane Fan
mallorn
hello @JaneFan !
I was trying to follow your example, but my Working point is deeper in assembly tree and I have to go through "reference path" to "get" the occurrence.
I'm still getting the coordinates to the local component origin...
oCompDef.Occurrences.ItemByName(TempRefChain(0))
Dim stepOcc As ComponentOccurrence = flightOcc.Definition.Occurrences.ItemByName(TempRefChain(1))
Dim endPlateOcc As ComponentOccurrence = stepOcc.Definition.Occurrences.ItemByName("stepEndplate")
Function GetRotation(oCompDef As ComponentDefinition, prefix As String, viewRepWithPrefix As String)
Dim angle As Double = 0
Dim ref As String = Right(viewRepWithPrefix, viewRepWithPrefix.Length-prefix.Length)
Dim TempRefChain() As String = ref.Split(".")
Dim flightOcc As ComponentOccurrence = oCompDef.Occurrences.ItemByName(TempRefChain(0))
Dim point0, point1 As WorkPoint
Dim wp As WorkPoint
For Each wp In endPlateOcc.Definition.WorkPoints
	If wp.Name = "Center Point" Then
		Logger.Trace(wp.Name & ": " & wp.Point.X & "|" & wp.Point.Y & "|" & wp.Point.Z)
		point0 = wp
	ElseIf wp.Name = "outCenterPoint" Then
		point1 = wp
Next wp
Dim point0Proxy, point1Proxy As WorkPointProxy
Call endPlateOcc.CreateGeometryProxy(point0, point0Proxy)
Call endPlateOcc.CreateGeometryProxy(point1, point1Proxy)
Logger.Trace("point0Proxy: " & point0Proxy.Point.X & "|" & point0Proxy.Point.Y & "|" & point0Proxy.Point.Z)
Logger.Trace("point1Proxy: " & point1Proxy.Point.X & "|" & point1Proxy.Point.Y & "|" & point1Proxy.Point.Z)
End Function
My Proxy points return the same coordinates, as WorkPoints (and they shouldn't, as they are not the same according to main Assembly), here is an output example for my files with different values of point1 coordinates :
	TRACE|creating view stepView|flight:1.step:1
	TRACE|Center Point: 0|0|0
	TRACE|outCenterPoint: 0|-96,515|0
	TRACE|point0Proxy: 0|0|0
	TRACE|point1Proxy: 0|-96,515|0
	TRACE|creating view stepView|flight:1.step:9
	TRACE|creating view stepView|flight:2.step:1
Tomasz Malinowski
