Cloud Line Drawing Tool
ss13953642009
ss13953642009
Looking for a useful cloud line drawing tool to highlight the modified areas in the blueprint.
machiel.veldkamp
Have you seen this?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-create-revi...
Hopefully this will solve your question 🙂
___________________________
ss13953642009
Hello, I understand this method, but the radius of the cloud lines generated this way is inconsistent, even when the Minimum/Maximum arc length is adjusted to the same value. Also, if I want to generate a rectangular cloud line, I need to mark points multiple times to ensure the cloud line closely resembles a rectangle. I currently have a plugin that can create rectangular cloud lines, but I want to avoid being limited to rectangles. I want to be able to create cloud lines with equal arc lengths as long as a closed polygon is recognized in the sketch.
JelteDeJong
I'm not sure which version of Inventor you use. But in Inventor 2024 the "Revision Clouds" feature was introduced.
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=GUID-D9288AE0-7C0C-4738-AA69-3B855D5626CC
It appears to respect the minimum and maximum radii.
Jelte de Jong
Blog: hjalte.nl - github.com
