Close parameters window with API
CAD_CAM_MAN
Message 1 of 11
CAD_CAM_MAN
I am building an application (for Inventor 2015) that will crash Inventor if the user runs it with the parameters window open. I would like to close the parameters window programmatically before the function causing the crash is executed. Is it possible to close the parameters window through the API if it is open for the active part document? I cannot figure out how to get access to the parameters window object. Does anybody have the syntax to do what I am asking?
Replies (10)
Message 2 of 11
I am not sure this is going to be usefull, but you could try this, witch is done in C#:
In the class declaration insert
[DllImport("User32.Dll", EntryPoint = "PostMessageA")] static extern bool PostMessage(IntPtr hWnd, uint msg, int wParam, int lParam);
const uint WM_KEYDOWN = 0x100;
Where you want to close the window, insert
PostMessage(InventorApp.MainFrameHWND, WM_KEYDOWN, Keys.Escape, 0);
InventorApp is the Inventor application object
That code should send a escape key stroke that would close any open dialog in Inventor.
That's the closest I could get to what you want to do...
Hope that will help
Message 3 of 11
CAD_CAM_MAN
Thank you Pierre, I should have mentioned I am working in VB.net on this project. Will see if I can work with your suggestion though as I had not thought to try an "ESC" key. Sure would prefer to get ahold of the window object though.
Message 4 of 11
ekinsb
Here's some simpler code that results in the same thing.  Essentially, when you press the escape key, the Select command is invoked, which has the side-effect of terminating the currently active command.  The code below will run the Select command.
    Dim selectCmd As ControlDefinition
    selectCmd = invApp.CommandManager.ControlDefinitions.Item("AppSelectNorthwestArrowCmd")
    selectCmd.Execute
Brian Ekins
Mod the Machine blog
Message 5 of 11
CAD_CAM_MAN
Thank you Brian for pointing me in this direction. I could not get your code to work as posted but by simply changing "App​SelectNorthwestArrowCmd" to "AppContextual_CancelCmd" the code seems to work as desired.
Message 6 of 11
CAD_CAM_MAN
Thank you Brian for pointing me in this direction. I could not get your code to work as posted but by simply changing the command to the cancel command it now seems to work as desired. I tried posting my code but the forum keeps rejecting. How do I post code on these posts (sorry new to forums)?
Message 7 of 11
rossano_praderi
When you post a new message...
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
Message 8 of 11
CAD_CAM_MAN
This is all I see (attached) when I try to post. Is there a setting for the other buttons? Also what is the quote button for? It does not seem to do anything.
Message 9 of 11
CAD_CAM_MAN
The attachment does not seem to work either. Regarding the last post I have no buttons below the Rich Text HTML and Preview tabs. I have to be missing something really obvious?
Message 10 of 11
rossano_praderi
Which browser are you using?
Do you have any add-in/plugin?
Are you receiving any kind of error messages from your browser?
Bregs
Rossano Praderi
Message 11 of 11
CAD_CAM_MAN
Have tried Microsoft internet explorer, and Firefox. I am going to put this in another post since this is not related to the original question
