ClientGraphics problem
GeorgK
Advisor Advisor
GeorgK
Hello together,
there is a question in the German forum to show the distance between a face and the CenterOfMass.
https://forums.autodesk.com/t5/inventor-deutsch/inventor-2019-schwerpunkt-im-modell-bemassen/m-p/836...
How could I do  this with ClientGraphics (show the dimensions)?
Thank you
Georg
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
Dimensions also can be created using 3D model annotations. Hoping that below VBA code may be helpful instead of client graphics.
Sub 3DLinearDimensions()
    Dim doc As PartDocument
    Set doc = ThisApplication.ActiveDocument
    Dim oDef As PartComponentDefinition
    Set oDef = doc.ComponentDefinition
    Dim oAnnotationFace As Face
    Set oAnnotationFace = ThisApplication.CommandManager.Pick(kPartFaceFilter, "Select a face to add Model linear dimension")
    Dim oAnnotationPlaneDef As AnnotationPlaneDefinition
    Set oAnnotationPlaneDef = oDef.ModelAnnotations.CreateAnnotationPlaneDefinitionUsingPlane(oAnnotationFace)
    ' Set a reference to the TransientGeometry object.
    Dim oTG As TransientGeometry
    Set oTG = ThisApplication.TransientGeometry
    Dim oPt As Point
    Set oPt = oTG.CreatePoint(3, 3, 3)
    Dim oCenterOfMass As Point
    Set oCenterOfMass = oDef.MassProperties.CenterOfMass
    Dim oWpt As WorkPoint
    Set oWpt = oDef.WorkPoints.AddFixed(oCenterOfMass)
    Dim oFace As Face
    Set oFace = ThisApplication.CommandManager.Pick(kPartFaceFilter, "Select a face")
    Dim oIntent1 As GeometryIntent
    Set oIntent1 = oDef.CreateGeometryIntent(oFace)
    Dim oIntent2 As GeometryIntent
    Set oIntent2 = oDef.CreateGeometryIntent(oWpt)
    Dim oLinearDimDef As LinearModelDimensionDefinition
    Set oLinearDimDef = oDef.ModelAnnotations.ModelDimensions.LinearModelDimensions.CreateDefinition(oIntent1, oIntent2, oAnnotationPlaneDef, oPt, kVerticalDimensionType)
    Dim oLinearDim As LinearModelDimension
    Set oLinearDim = oDef.ModelAnnotations.ModelDimensions.LinearModelDimensions.Add(oLinearDimDef)
End Sub
To demonstrate, a screencast is prepared and uploaded to below link.
https://autode.sk/2Jz7lmD
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
GeorgK
Hello @chandra.shekar.g,
Thank you very much. That solves the problem for Inventor 2019 but not for older versions.
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
LinearModelDimensions.Add (ModelAnnotations) method is introduced in Inventor 2018 and later versions. For more details, refer Inventor 2018 API help documentation link.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-656FEC41-1A6E-4E11-9DA4-B08F254F85A2
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
