Client Graphics Normal
gerrardhickson
gerrardhickson
Hi All,
In the help file under "Client Graphics - Triangle API Sample " There is some sample code that creates a cylinder. Near the end of that sample, the code defines and assigns a normal for the client graphics 'surface'. What is the purpose of this? I've run the code without the normal, and it appears to do what I want. Are there cases when defining the normal is important?
FINET_Laurent
Hi @gerrardhickson,
It is the same for workplanes. For instance here we have a plane that is orange :
If I look the other side of the workplane, it will be blue.
Now I can right click on it and select "Invert normal" :
And now the colors are swapped :
Here is an explanation of what the normal of a surface is. The swap we did is simply defining where the arrow is pointing (two solutions)
Kind regard,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
gerrardhickson
@FINET_Laurent , yeah I understand what a normal is in the context of planes and why you might want to control them in for a work plane. But those reasons don't seem to apply to client graphics. E.g. you can't interact with client graphics the same way that you can with a work plane.
FINET_Laurent
@gerrardhickson
The normal is often used in 3D computer graphics (notice the singular, as only one normal will be defined) to determine a surface's orientation toward a light source for flat shading, or the orientation of each of the surface's corners (vertices) to mimic a curved surface with Phong shading.
The rangebox appear non-shaded on my end if I remove those lines.
Kind regards,
FINET L.
