Clear Thumbnails with white BG Ilogic
davis.j
davis.j
I have modified the following code using assets from other threads. (Credit to those before me 🙂)
What the rule does is temporarily turn off some vault functionality to ignore prompts and errors. It then proceeds to snap and new thumbnail photo for each unique component in throughout the assembly tree. I've got it to a point that works but it is not perfect and large assemblies behave oddly sometimes. My end goal to have a stable rule that can be executed with no errors (Hopefully.)
Can someone test this with me. I am trying to identify why sometimes the parts don't close and continue and rather stay open. It is annoying to have to close them all after if the rule doesn't close them automatically.
Also how can I specify the code to look for derived parts in a given part and then open those as well and re-snap the thumbnail photo.
Idea Thread:
Save all thumbnails with white background.
Sub Main()
	oColorScheme = ThisApplication.ActiveColorScheme.Name
	oBackGroundType = ThisApplication.ColorSchemes.BackgroundType
	ThisApplication.ColorSchemes.Item("Presentation").Activate
	ThisApplication.ColorSchemes.BackgroundType = _
	BackgroundTypeEnum.kOneColorBackgroundType
	Dim a = iLogicVb.Automation
	a.RulesOnEventsEnabled = False
	If ThisDoc.Document.DocumentType <> kAssemblyDocumentObject Then
		MessageBox.Show("This rule must be run from an Assembly.", "Error", MessageBoxButtons.OK, MessageBoxIcon.Stop, MessageBoxDefaultButton.Button1)
	Exit Sub
    Dim oAsmDoc As Document
    oAsmDoc = ThisApplication.ActiveDocument
    Call MakeNewThumbnail(oAsmDoc)
    Dim oSubDoc As Document
    For Each oSubDoc In oAsmDoc.AllReferencedDocuments
        If oSubDoc.IsModifiable Then
            oSubDoc = ThisApplication.Documents.Open(oSubDoc.FullFileName, True)
            Call MakeNewThumbnail(oSubDoc)
            oSubDoc.Close
	Next
	a.RulesOnEventsEnabled = True
	ThisApplication.ColorSchemes.Item(oColorScheme).Activate
	ThisApplication.ColorSchemes.BackgroundType = oBackGroundType
End Sub
Sub MakeNewThumbnail(oDoc As Document)
    On Error Resume Next
    With oDoc.ObjectVisibility
        .AllWorkFeatures = False
        .Sketches = False
        .Sketches3D = False
    End With
    oDoc.SetThumbnailSaveOption (kActiveComponentIsoViewOnSave)
    oDoc.Save
    On Error GoTo 0
End Sub
JelteDeJong
I don't have VBa installed therefore I can't test the code. but some things that you could try:
oSubDoc.Close
this function has an optional parameter: "SkipSave". (Optional input Boolean that specifies whether to skip the save. If SkipSave is set to True, it indicates that the changes to the document should not be saved and that the document should be closed silently. If SkipSave is set to False, it indicates that the normal save process should be followed.)
You have already saved the file before you close it. Therefore you can close without the extra save action while closing that possibly could go wrong. That would look like this.
oSubDoc.Close(True)
for the "save" action you use:
oDoc.Save
You could try to use the function "Save2(Optional SaveDependents As Boolean = True)" Saving dependent files could go wrong and I guess that you don't care if dependent files are saved (it's not necessary for creating thumbnails in the original part). Therefore you could skip that save action like this:
oDoc.Save2(False)
 I'm a bit surprised that you don't get the derived parts with:
Next
Jelte de Jong
Blog: hjalte.nl - github.com
davis.j
Thanks @JelteDeJong
I have implemented some of your ideas.
I have added some code from here:
https://forums.autodesk.com/t5/inventor-customization/ilogic-to-change-read-only-state-of-file-s/td-...
This is so I can save the read only parts.
At this point I have to run the rule twice.
Is there any way to consolidate this rule to only have to run it once. I'm thinking large assemblies take some time and having to do the rule twice would be annoying 🙂. The first time I run the rule it changes all locked parts but not the parts that are in a checkout-able state that are read only. (3D model design vs released)
Current Rule:
Sub Main()
	strPath = System.IO.Directory.GetParent(ThisDoc.Document.FullFileName).FullName
	Dim dir As New System.IO.DirectoryInfo(strPath)
	For Each File As System.IO.FileInfo In dir.GetFiles("*", System.IO.SearchOption.AllDirectories)
	    File.IsReadOnly = False
	Next
	Exit Sub
            oSubDoc.Close(True)
	Next
End Sub
        .Sketches = False
        .Sketches3D = False
    End With
    oDoc.Save
    On Error GoTo 0
End Sub
Might anyone else be able to test this with me?
davis.j
Looks like all I had to do was add:
oAsmDoc.Save
And I also added this:
Ignore Vault popup when opening/closing files with API?
So far this rule is working and I will be testing it out for a while to see if they are any more quirks to work out:
Sub Main()
Dim VaultAddin As ApplicationAddIn = ThisApplication.ApplicationAddIns.ItemById("{48B682BC-42E6-4953-84C5-3D253B52E77B}")
	VaultAddin.Deactivate()
	Next
	Exit Sub
			oAsmDoc.Save
            oSubDoc.Close(True)
	Next
	VaultAddin.activate()
End Sub
        .Sketches = False
        .Sketches3D = False
    End With
    oDoc.Save
    On Error GoTo 0
End Sub
Setting to solved for now. 😃
davis.j
I have been using these two rules lately with success. One is for Current Level only, the other is for a part only list that will go through all parts. I use then use BOMTools App export Excel sheets after the Thumbnails are set to a white BG.
Clear Thumbnails (First Level)
Sub Main()
	Next
	Exit Sub
    For Each oSubDoc In oAsmDoc.ReferencedDocuments
			oAsmDoc.Save
            oSubDoc.Close(True)
	Next
    If oAsmDoc.IsModifiable Then
		oAsmDoc.Save
End Sub
        .Sketches = False
        .Sketches3D = False
    End With
    oDoc.Save
    On Error GoTo 0
End Sub
Clear Thumbnails (All Parts)
Sub Main()
	Next
	Exit Sub
			oAsmDoc.Save
            oSubDoc.Close(True)
	Next
End Sub
        .Sketches = False
        .Sketches3D = False
    End With
    oDoc.Save
    On Error GoTo 0
End Sub
