Clear Appearance
Clear Appearance
peteh
Clear Appearance
peteh
I want to accomplish this for an Inventor part in VB.NET code.
Tools Tab - Material and Appearance - Clear - Select All - OK
Is there example code?
xiaodong_liang
Autodesk Support
Autodesk Support
I believe this API is
PartComponentDefinition.ClearAppearanceOverrides ([AppearanceOverrideObjects] As Variant )
AppearanceOverrideObjects is an optional input ObjectCollection including the faces, features, work surfaces and bodies to clear their appearance overrides. If this argument is not provided, then it will clear all the appearance overrides in active design view. If an object is provided that does not have an override, it is ignored.
peteh
That works! - Thank you
I'm trying to do it, but in vba...
Could you give me the code for it ?
Thanks a lot,
RoyWickrama_RWEI
Glad to hear that you got this around. I need to get around this.
Could you reply with the code used. Thanks a lot!
RoyWickrama_RWEI
Being not a programmer, I am not able to explore your reply.
I would be most grateful if you could you reply with a sample code.
