Circular or Rectangular Pattern "Sketch Name"
isocam
isocam
Can anybody help?
I need to know what sketch is associated to either a "Rectangular"or "Circular"array.
This is so I can filter out sketches that are not repeated in an array.
Here is my code so far (Circular Array).
Dim oCP As CircularPatternFeature
   For Each oCP In oDef.Features.CircularPatternFeatures
     THIS IS THE TROUBLE LINE  If sketch = oCP.Parent Then
          Set oCP = oDef.Features.CircularPatternFeatures.Item(oCP.Name)
          Set oPar = oCP.Count
          Xcount = oPar.Value
          Set oPar = oCP.Angle
          FitAngle = oPar.Value * Rad
          If FitAngle = 360 Then
             IncrementalAngle = 360 / Xcount
          Else
             IncrementalAngle = FitAngle / (Xcount - 1)
          For Counter = 1 To Xcount
              Set oFPE = oCP.PatternElements.Item(Counter)
              If oFPE.Suppressed = False Then
                 AbsoluteAngle = (Counter - 1) * IncrementalAngle
                 REM Call CircularArray
          Next Counter
   Next
I have a simple test part containing an extruded disk (Sketch1) and 8 holes on a pcd (Sketch2). I only want to array a sketch if it is arrayed,
Many thanks in advance!!!
IsoCAM
Hi isocam,
I would say that the Circular Array is the Parent of the Sketch. The way you have it written I believe you're asking if the sketch is the Parent of the Circular Array.
Regards
Mitch
Let me know if it helps... Kudos if it works!!!
isocam
Mitch,
Can you please give me a working example of the line of code I need to achieve this?
I cannot seem to get the correct code to do this!
Many thanks!!!!!
IsoCAM
Hi Isocam,
May I ask what exactly you are trying to do with the code? That way I have an idea when trying to fix it.
Regards
Mitch
Vladimir.Ananyev
Hi Isocam,
if you need a reference to the planar sketch where arrayed
geometry was sketched then look to these code samples:
Sub TEST_Rect()
  Dim oDoc As PartDocument
  Set oDoc = ThisApplication.ActiveDocument
  Dim oDef As PartComponentDefinition
  Set oDef = oDoc.ComponentDefinition
  'reference to rect. pattern
  Dim oRP As RectangularPatternFeature
  Set oRP = oDef.Features.RectangularPatternFeatures _
              .Item("Rectangular Pattern1")
  Dim oParentFeature As ExtrudeFeature 'one of PartFeature
  Set oParentFeature = oRP.ParentFeatures.Item(1)
  Dim oSketch As PlanarSketch
  Set oSketch = oParentFeature.Profile.Parent
  Debug.Print "Parent sketch: " & oSketch.Name
End Sub
Sub TEST_Circ()
  'reference to circ. pattern
  Set oCP = oDef.Features.CircularPatternFeatures _
              .Item("Circular Pattern1")
  Set oParentFeature = oCP.ParentFeatures.Item(1)
End Sub
 In both cases it is assumed that patterns were created using ExtrudeFeature objects.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
