Chosing which holes to dimension
haistshomie
haistshomie
Hi folks,
at first i want to excuse my english, i'm not a native speaker but i will try to be as understandable as possible.
The last view weeks i was trying to automate some of my drawings and right now i'm trying to dimension holes. I found some code that dimensions all the cylindric geometry in my drawing. Since I have several holes with the same dimensions I want to only dimension one of a kind and also want to change the texts if possible. My problem is: I haven't found an opportunity to chose "one of a kind" and not dimension the rest.
I think I also figured out how to edit the dimension texts (for example add the "H7") but i dont know how to hide the dimension text (for the M8). Probably there is a better way to dimension it with the thread dimension, but i also didn't figure that out.
As you see in the picture, I haven't done the positioning yet but i know how to do that.
I use Inventor 2020 and here is the code I use so far:
Dim oSheet As Sheet = ActiveSheet.Sheet
For Each oView As DrawingView In oSheet.DrawingViews
	For Each oCurve As DrawingCurve In oView.DrawingCurves
		If oCurve.CurveType = CurveTypeEnum.kCircleCurve
			Dim oIntent As GeometryIntent = oSheet.CreateGeometryIntent(oCurve, PointIntentEnum.kCircularLeftPointIntent)
			Dim oPoint As Point2d = oIntent.PointOnSheet.Copy
			Dim oVector As Vector2d = oCurve.CenterPoint.VectorTo(oPoint)
			oVector.ScaleBy(.1)
			oVector.AddVector(ThisApplication.TransientGeometry.CreateVector2d(oVector.X, Abs(oVector.X)))
			oPoint.TranslateBy(oVector)
			oSheet.DrawingDimensions.GeneralDimensions.AddDiameter(oPoint, oIntent, False)
	Next
Next
JelteDeJong
Just a first fast reply. You might want to have a look at my blog post: "Automatically generate hole position dimensions". It ticks off all of the secondary features you are looking for. I will have a look if i also can add will the primary feature 😉
Jelte de Jong
Blog: hjalte.nl - github.com
haistshomie
Thanks for your reply, unfortunately i can't open the link, because it says that the url wasn't found.
Greetings
Colin
JelteDeJong
Strange, lot of good stuff there. but not httpS. Some browsers don't like that. Anyway,  I have an improved version.
It generates lots of things that you did not ask for. And among other settings, you can turn them off. Have a look at the settings on line 11 to 14 and 31 to 37.
Public Class ThisRule
    Private _doc As DrawingDocument
    Private _sheet As Sheet
    Private _view As DrawingView
    Private _intents As List(Of GeometryIntent) = New List(Of GeometryIntent)()
    Private _threadDrawingCurves As List(Of DrawingCurve) = New List(Of DrawingCurve)()
    Private _centerPointIntents As List(Of GeometryIntent) = New List(Of GeometryIntent)()
    ' Some settings here for you to change.
	Private _countSameDimensions = True
    Private _stackedDimensions As Boolean = False
    Private _firstOffset As Double = 1.2 'Cm
    Private _offsetDimension As Double = 0.8 'Cm
    Public Sub Main()
        _doc = ThisDoc.Document
        _sheet = _doc.ActiveSheet
        _view = ThisApplication.CommandManager.Pick(
                       SelectionFilterEnum.kDrawingViewFilter,
                       "Select a drawing view")
        If (_view Is Nothing) Then
			MsgBox("Nothing was selected.")
			return
        Dim transaction As Transaction = ThisApplication.TransactionManager.StartTransaction(_doc, "Generate dimensions")
        CreateIntentList()
        ' Comment out features that you dont want/need!
        CreateHorizontalDimensions()
        CreateVerticalDimensions()
        CreateMarks()
        AddDiameterDimensionToCircles()
        AddThreadNotes()
        CreateHorizontalOuterDimension()
        CreateVerticalOuterDimension()
        transaction.End()
    End Sub
    Public Sub CreateHorizontalDimensions()
        Dim orderedIntents = _intents.OrderBy(Function(s) s.PointOnSheet.X)
        Dim orderedCenterIntents = _centerPointIntents.OrderBy(Function(s) s.PointOnSheet.X)
        Dim pointLeft = orderedIntents.First
        Dim pointRight = Nothing
        Dim lastX = pointLeft.PointOnSheet.X
        Dim offset As Double = _firstOffset
        For Each intent As GeometryIntent In orderedCenterIntents
            pointRight = intent
            If (AreEqual(pointRight.PointOnSheet.X, lastX)) Then
                Continue For
            CreateHorizontalDimension(pointLeft, pointRight, offset)
            If _stackedDimensions Then
                offset = offset + _offsetDimension
            Else
                pointLeft = pointRight
            lastX = pointRight.PointOnSheet.X
        Next
        pointRight = orderedIntents.Last
    End Sub
    Private Sub CreateHorizontalDimension(pointLeft As GeometryIntent,
                                          pointRight As GeometryIntent,
                                          distanceFromView As Double)
        Dim textX = pointLeft.PointOnSheet.X +
                (pointRight.PointOnSheet.X - pointLeft.PointOnSheet.X) / 2
        Dim textY = _view.Position.Y + _view.Height / 2 + distanceFromView
        Dim pointText = ThisApplication.TransientGeometry.CreatePoint2d(textX, textY)
        _sheet.DrawingDimensions.GeneralDimensions.AddLinear(
            pointText, pointLeft, pointRight, DimensionTypeEnum.kHorizontalDimensionType)
    End Sub
    Private Sub CreateHorizontalOuterDimension()
        Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.X)
        Dim pointRight = orderedIntents.Last
        CreateHorizontalDimension(pointLeft, pointRight, _firstOffset + _offsetDimension)
    End Sub
    Public Sub CreateVerticalDimensions()
        Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.Y)
        Dim orderedCenterIntents = _centerPointIntents.OrderByDescending(Function(s) s.PointOnSheet.Y)
        Dim lastY = pointLeft.PointOnSheet.Y
            pointRight = intent
            If (AreEqual(pointRight.PointOnSheet.Y, lastY)) Then
                Continue For
            CreateVerticalDimension(pointLeft, pointRight, offset)
            Else
            lastY = pointRight.PointOnSheet.Y
        Next
    End Sub
    Private Sub CreateMarks()
        Dim done As List(Of GeometryIntent) = New List(Of GeometryIntent)()
        Dim firstIntent = orderedCenterIntents(0)
        Dim secondIntent = Nothing
        For i = 1 To orderedCenterIntents.Count - 1
            secondIntent = orderedCenterIntents(i)
            If (AreEqual(firstIntent.PointOnSheet.Y, secondIntent.PointOnSheet.Y)) Then
                CreateCenterLine(firstIntent, secondIntent)
                done.Add(firstIntent)
                done.Add(secondIntent)
            firstIntent = secondIntent
        Next
        orderedCenterIntents = _centerPointIntents.OrderByDescending(Function(s) s.PointOnSheet.X)
            If (AreEqual(firstIntent.PointOnSheet.X, secondIntent.PointOnSheet.X)) Then
        Next
            If (done.Contains(intent)) Then
                Continue For
            _sheet.Centermarks.Add(intent)
        Next
    End Sub
    Public Sub CreateCenterLine(pointLeft As GeometryIntent, pointRight As GeometryIntent)
        Dim collection = ThisApplication.TransientObjects.CreateObjectCollection()
        collection.Add(pointLeft)
        collection.Add(pointRight)
        _sheet.Centerlines.Add(collection)
    End Sub
    Private Sub CreateVerticalDimension(pointLeft As GeometryIntent,
        Dim textY = pointLeft.PointOnSheet.Y +
                (pointRight.PointOnSheet.Y - pointLeft.PointOnSheet.Y) / 2
        Dim textX = _view.Position.X - _view.Width / 2 - distanceFromView
            pointText, pointLeft, pointRight, DimensionTypeEnum.kVerticalDimensionType)
    End Sub
    Private Sub CreateVerticalOuterDimension()
        Dim pointLeft = orderedIntents.Last
        Dim pointRight = orderedIntents.First
        CreateVerticalDimension(pointLeft, pointRight, _firstOffset + _offsetDimension)
    End Sub
    Private Sub AddIntent(Geometry As DrawingCurve, IntentPlace As Object, onLineCheck As Boolean)
        Dim intent As GeometryIntent = _sheet.CreateGeometryIntent(Geometry, IntentPlace)
        If intent.PointOnSheet Is Nothing Then Return
        If onLineCheck Then
            If (IntentIsOnCurve(intent)) Then
                _intents.Add(intent)
        Else
    End Sub
    Private Function IntentIsOnCurve(intent As GeometryIntent) As Boolean
        Dim Geometry As DrawingCurve = intent.Geometry
        Dim sp = intent.PointOnSheet
        Dim pts(1) As Double
        Dim gp() As Double = {}
        Dim md() As Double = {}
        Dim pm() As Double = {}
        Dim st() As SolutionNatureEnum = {}
        pts(0) = sp.X
        pts(1) = sp.Y
        Try
            Geometry.Evaluator2D.GetParamAtPoint(pts, gp, md, pm, st)
        Catch ex As Exception
            Return False
        End Try
        Return True
    End Function
    Private Sub CreateIntentList()
        For Each drawingCurve As DrawingCurve In _view.DrawingCurves
            If (DrawingCurve.EdgeType = DrawingEdgeTypeEnum.kThreadEdge) Then
                _threadDrawingCurves.Add(DrawingCurve)
            Select Case DrawingCurve.ProjectedCurveType
                Case _
                        Curve2dTypeEnum.kCircleCurve2d,
                        Curve2dTypeEnum.kCircularArcCurve2d,
                        Curve2dTypeEnum.kEllipseFullCurve2d,
                        Curve2dTypeEnum.kEllipticalArcCurve2d
                    AddIntent(DrawingCurve, PointIntentEnum.kCircularTopPointIntent, True)
                    AddIntent(DrawingCurve, PointIntentEnum.kCircularBottomPointIntent, True)
                    AddIntent(DrawingCurve, PointIntentEnum.kCircularLeftPointIntent, True)
                    AddIntent(DrawingCurve, PointIntentEnum.kCircularRightPointIntent, True)
                    AddIntent(DrawingCurve, PointIntentEnum.kEndPointIntent, False)
                    AddIntent(DrawingCurve, PointIntentEnum.kStartPointIntent, False)
                    If (DrawingCurve.ProjectedCurveType = Curve2dTypeEnum.kCircleCurve2d) Then
                        Dim intent = _sheet.CreateGeometryIntent(DrawingCurve, PointIntentEnum.kCenterPointIntent)
                        _centerPointIntents.Add(intent)
                Case _
                        Curve2dTypeEnum.kLineCurve2d,
                        Curve2dTypeEnum.kLineSegmentCurve2d
                Case _
                    Curve2dTypeEnum.kPolylineCurve2d,
                    Curve2dTypeEnum.kBSplineCurve2d,
                    Curve2dTypeEnum.kUnknownCurve2d
                    ' Unhandled curves types
                Case Else
            End Select
        Next
    End Sub
    Private Sub AddDiameterDimensionToCircles()
        Dim doneCurves As New List(Of DrawingCurve)()
        Dim doneDims As New List(Of DoneDiameter)()
        For Each intent As GeometryIntent In _intents
            Dim geo = intent.Geometry
            If (geo.type <> ObjectTypeEnum.kDrawingCurveObject) Then
                Continue For
            Dim curve As DrawingCurve = geo
            If (doneCurves.Contains(curve)) Then Continue For
            doneCurves.Add(curve)
            If (curve.ProjectedCurveType <> Curve2dTypeEnum.kCircleCurve2d) Then
                Continue For
            Dim rangeBox = curve.Evaluator2D.RangeBox
            Dim radius = (rangeBox.MaxPoint.X - rangeBox.MinPoint.X) / 2
            Dim doneDim = doneDims.FirstOrDefault(Function(d) d.Radius = radius)
            If (doneDim Is Nothing Or Not _countSameDimensions) Then
                Dim x = curve.CenterPoint.X + radius
                Dim y = curve.CenterPoint.Y + radius
                Dim textPoint = ThisApplication.TransientGeometry.CreatePoint2d(x, y)
                Dim dimension = _sheet.DrawingDimensions.GeneralDimensions.AddDiameter(textPoint, intent)
                Dim d As New DoneDiameter()
                d.Dimension = dimension
                d.Radius = radius
                doneDims.Add(d)
            Else
                doneDim.Count += 1
        Next
        For Each doneDim As DoneDiameter In doneDims
            If (doneDim.Count = 1) Then Continue For
            Dim txt = String.Format("<DimensionValue/> ({0}x)", doneDim.Count)
            doneDim.Dimension.Text.FormattedText = txt
        Next
    End Sub
    Private Sub AddThreadNotes()
        Dim notes = _sheet.DrawingNotes.HoleThreadNotes
        For Each curve As DrawingCurve In _threadDrawingCurves
            Dim x = curve.CenterPoint.X - radius * 5
            Dim y = curve.CenterPoint.Y - radius * 5
            notes.Add(textPoint, curve)
        Next
    End Sub
    Private Class DoneDiameter
        Public Property Dimension As DiameterGeneralDimension
        Public Property Count As Integer = 1
        Public Property Radius As Double
    End Class
    Private Function AreEqual(d1 As Double, d2 As Double)
        Return (Math.Abs(d1 - d2) < 0.000001)
    End Function
    ' This code was written by Jelte de Jong, and published on www.hjalte.nl
End Class
Jelte de Jong
haistshomie
At first I really want to thank you for labour input, I appreciate it a lot!
The code somehow works as it should, but its highly more complex than everything i created my own. I will probably need a lot of time understanding what it does in the different steps, and to modify everything to that certain assembly, since I just started with automation in iLogic. There is just one thing that still confuses me:
Right now I'm running it in an assembly in which I hide some plates and in every sheet I show just a single one. When I run the code in the assemblyrawing, for some holes it recognizes same diameters but in others it doesn't. When I run the code in the partdrawing (same part as shown in the assembly drawing) it works perfectly. Do you maybe now why that is? The holes are made by the same feature, so the diameter can not be different, I just wonder if that is because i hid the geometry.
Thank you in advance!
JelteDeJong
The rule does not check the part for the hole diameters. It will just look at the (circular) lines in the drawing and add a dimension. Therefore it will not count lines that are hidden.
Jelte de Jong
haistshomie
Okay, strange, then there must be an error anywhere else. I think that might be specific anywhere in my assembly.
Thanks again for your help, have a noce weekend!
