Cherry Picking a file to process
andrew_canfield
andrew_canfield
Some drawings need to be converted to pdf's (separate thread in progress for that)
How can files be selected to be opened, processed & closed.
Everything is in one large folder, some have been converted others are WIP:
(it's a PDM system & task scheduler can't access the working folder).
I'm thinking along the lines:
(then come up with a way to add a list of numbers)
where the number can be concatenated into the file path & use "for, next" - to work through the list?
Pretty simple but testing me!
In my test i had the line for A= 1 to 3 & the message box opened up three time with the number changing.
altered to 11;22;33;44  hoping the message box would display 11 then 22 then 33
I wish task scheduler would work!
Regards
Andrew
andrew_canfield
This looks promising, just need to replace ("Red", "Green", "Blue") with the file number - in a user friendly way.
Create an array of drawing numbers..
Sub ArrayLoop()
    Dim avColors As Variant
    Dim vItem As Variant
    avColors = Array("Red", "Green", "Blue")
    For Each vItem In avColors
        Debug.Print vItem
    Next
End Sub
chandra.shekar.g
Autodesk Support
Autodesk Support
@andrew_canfield,
Hoping that below VBA code helps
Sub ArrayLoop()
    avColors = Array(11,22,33,44)
        Debug.Print vItem
    Next
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
