Checking whether the part is in the Assembly, ilogic
Rogov_Sergey
Rogov_Sergey
Can you help with the verification rule?
1. There is a variable with a list of values "X" = 1,2,3,4,5,6.
2. If X=1 and part #1 is not in the Assembly, then rule 1 is followed. if X=1 part #1 is in the Assembly, then rule 2 is followed.
3. If X=2 and part #2 is not in the Assembly, then rule 1 is followed. if X=2 part #2 is in the Assembly, then rule 2 is followed.
4. ...
Находите сообщения полезными? Поставьте Нравится (Like) этим сообщениям!
На ваш вопрос успешно ответили? Нажмите кнопку 'Утвердить решение'
Рогов Сергей/ Rogov Sergey
Инженер-конструктор
marcin_otręba
when x store part number values:
Dim x As String = "1,2,3,4,5,6,7"
Dim doc As Document
Dim ass As AssemblyDocument = ThisDoc.Document
For Each doc In ass.AllReferencedDocuments
If x.Contains(doc.PropertySets.item(3).Item("Part Number").value) Then ' idk wchat you want to check and compare
	iLogicVb.RunExternalRule("ruleFileName1")
Else
iLogicVb.RunExternalRule("ruleFileName2")
Next
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
