Checking to see if a sketch is in edit mode?
keithjk
keithjk
I need to be able to delete a sketch in my .idw file.  The snippet below works perfectly if the sketch is not in "edit mode" but it crashes if it is in edit mode. I can place "oSketch.exitedit" in the loop but that causes it to crash if it is not in edit mode.
Any suggestions on how to check to see if a sketch is in edit mode?
Dim oSketch As DrawingSketch = Nothing
Dim oSketches As DrawingSketches = oDrawingView.Sketches
For Each oSketch In oSketches
 If oSketch.Name = "skSubPanelSketch" Then
   oSketch.Delete()
  Exit For
Next
keithjk
I guess this works.  But I would like to know if there is a cleaner way of doing it.
Try
oSketch.ExitEdit()
Catch
' do nothing
End Try
oSketch.Delete()
Exit For
Debug.Print("Exiting loop")
Next
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi KeithJK,
If the sketch is in edit mode, sketch can not be deleted. So, sketch needs exit form edit mode.
Please try the following sample code to delete sketch.
        oSketches = oDrawingView.Sketches
        For Each oSketch As DrawingSketch In oSketches
                Try
                    'sketch will be deleted if it is not edit mode.
oSketch.Delete() Catch
'If sketch is in edit mode. sketch needs exit from edit mode. oSketch.ExitEdit() oSketch.Delete() End Try Exit For End If Next
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
frederic.vandenplas
Hi, this is what you need, for neat environment checking.
Sub Environment()
  Dim oEnvs As Environment
  Set oEnvs = ThisApplication.UserInterfaceManager.ActiveEnvironment
  Debug.Print oEnvs.InternalName
  'When editing sketches in drawings (on drawingview), it returns: DLxDrawingSketchEnvironment
End Sub
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
