Check if partlist is sortet
Darkforce_the_ilogic_guy
Advisor Advisor
I have a ilogic that sort a Part liste by Part number like this.. Is there anyway to check if the partlist is already sortet ?
JhoelForshav
Hi @Darkforce_the_ilogic_guy
You didn't mention if you sort by string or numeric value.
Here's an example if you sort by string:
Dim oSheet As Sheet = ThisDrawing.ActiveSheet.Sheet
Dim oPartsList As PartsList = oSheet.PartsLists(1)
Dim Sorted As Boolean = True
For i = 1 To oPartsList.PartsListRows.Count - 1
    Dim currentPN As String = oPartsList.PartsListRows(i).Item("PART NUMBER").Value.ToString
    Dim nextPN As String = oPartsList.PartsListRows(i + 1).Item("PART NUMBER").Value.ToString
    If String.Compare(currentPN, nextPN, StringComparison.OrdinalIgnoreCase) > 0 Then
        Sorted = False
        Exit For
Next
If Sorted Then
    MsgBox("The parts list is sorted.")
Else
    MsgBox("The parts list is not sorted.")
I use this code to Sort it
Try
Dim SheetsNumber
SheetsNumber = ThisApplication.ActiveDocument.Sheets.Count
For i = 1 To SheetsNumber
Dim oPartslistCheck As PartsList
oPartslistCheck = ThisApplication.ActiveDocument.Sheets(i).PartsLists(1)
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Call oDoc.SelectSet.Select(oPartslistCheck)
InventorVb.RunMacro("ApplicationProject", "PartsListSort", "FormatSelectedPartsList")
Next
Catch
End Try
...VBA Code
Option Explicit
Option Base 1
Public Function GetActiveDrawing() As DrawingDocument
If ThisApplication.ActiveDocument.DocumentType = kDrawingDocumentObject Then
Set GetActiveDrawing = ThisApplication.ActiveDocument
Else
MsgBox "Must have a drawing active", vbOKOnly, "Error"
End Function
Public Function GetSelectedPartsList() As PartsList
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = GetActiveDrawing
If oDrawDoc Is Nothing Then Exit Function
Dim oSelectSet As SelectSet
Set oSelectSet = oDrawDoc.SelectSet
If oSelectSet.Count = 0 Then Exit Function
If oSelectSet.Item(1).Type <> kPartsListObject Then Exit Function
Set GetSelectedPartsList = oSelectSet.Item(1)
End Function
Public Function FormatPartsList(oPartsList As PartsList) As PartsList
On Error Resume Next
oPartsList.Sort "PART NUMBER", True
oPartsList.Renumber
oPartsList.SaveItemOverridesToBOM
If Err Then
Err.Clear
MsgBox "Could not sort Parts List", , "Error"
Set FormatPartsList = oPartsList
End Function
Public Sub FormatSelectedPartsList()
Set oPartsList = GetSelectedPartsList
If oPartsList Is Nothing Then Exit Sub
FormatPartsList oPartsList
End Sub
JhoelForshav
When I use your macro to sort a partslist, then try the code I provided in my previous reply, it works fine for me. Does it not work for you?
If it doesn't work, could you please provide a dataset (assembly and drawing) where it doesn't work so I can investigate further? 🙂
